4500X VSL issue
umer zubairi
Friends, I'm trying to configure VSS on a pair of 16 port 4500X.
However, whilst creating the VSL I'm getting below and Port-channel isn't coming up.
EC-5-CANNOT_BUNDLE2: Te1/1 is not compatible with Po5 and will be suspended (trunk mode of Te1/1 is dynamic, Po5 is trunk)
Please help!
29 Replies 29
I agree with you. But I am looking your error:
trunk mode of Te1/2 is dynamic, Po39 is trunk
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Yes, that's for sure there's a config mismatch but don't know whether it's LACP negotiation problem or a normal trunking mismatch.
Tomorrow I'm going to test it again, I'll definitely keep you posted on updates.
Thanks so much for your valuable inputs!
Kind Regards,
Ok, can you do it in other order:
- configure interfaces
- add interfaces into PO
- finalize configuration of PO.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
You mean at the end I add 'switch virtual link' command to the port-channel?
Yeah I mean configure everything you did except the virtual link in PO.
When you have added interfaces into PO, then go back to PO and add switch virtual link
Francesco
Did you tried that?
Francesco
Gonna try this first thing in the morning hope thing go well with the VSS creation.
Thanks again I'll keep you posted on updates.
I didn't configured anything like this on my physical interfaces.
Actually, switch automatically added these lines when I applied VSL port-channel on these physical ports.
I tried a normal port-channel and found no issues as both the ports joined the channel group within seconds. But when I try making the VSL it always gives same warning and ports get suspended.
That's why I just want to be sure the config is correct. Can you paste the config on the interfaces as well and let us know.
Or share the config you have because on outputs it seems that interfaces and PO are not equally configured.
Francesco
Deepak Kumar
Please check some configuration:
1. Interface speed should be same in a bundle.
2. If there is any Encapsulation is already configured then remove the encapsulation or try with same on all port in a bundle.
3. Any VLAN configuration on the Switch port etc.
I think the best way to resolve this issue, first set the default to this particular interface and configure again in the bundle. "Default interface Te1/1" command for the same.
Deepak Kumar
Deepak Kumar,
Plz check my configs and show outputs as I've almost tried everything to get it up and running.
Kind Regards,
Your VLAN configuration is looking wrong on Port-Channel and Interfaces.
Please reset default to your Interface and change some setting on Port-Channel interface as
Access Mode VLAN and  Trunking Native Mode VLAN:
Your current configuration as below
On Port-Channel
Access Mode VLAN: 0 (Inactive)
Trunking Native Mode VLAN: 0 (Inactive)
and on both interfaces:
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Capture Mode Disabled
Capture VLANs Allowed: ALL
Please match all settings and check again.
Deepak Kumar
Deepak Kumar,
How to configure them to be matched with each other I mean interfaces do not support all the commands.
Do you know the commands to be used here?
Hello
Just like to add when creating a VSL PC, its best to let the PC get created automatically.
May I suggest try
1) delete any related Logical PC you wish to use as the vsl
2) default the physical interface of the PC and SHUT them down.
3) assign Just the port-channel group X ON mode to the physical interfaces ( PC wil get created)
4) apply virtual link number to pc and create VSL config
5) enable physical interfaces
default int ran x/x ,x
int ran x/x , x
shut
channel-group X mode on
int port-channel x
switchport
switch virtual-link x
no shut
switch virtual domain xx
switch x
int ran x/x , x
no shut
res
Paul
Kind Regards
Paul
Thanks Paul, I've almost tried everything.
Check below show outputs from port-channel and physical interfaces, especially the red highlighted part
Switch#sh int port-channel 39 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switch#
Switch#
Switch#sh int te
Switch#sh int tenGigabitEthernet 1/1 sw
Switchport: Enabled
Operational Mode: down (suspended member of bundle Po39)
Voice VLAN: none
Switch#
Switch#
Switch#sh int te
Switch#sh int tenGigabitEthernet 1/2 sw
Switchport: Enabled
Voice VLAN: none
