03-25-2016 07:20 AM - edited 03-05-2019 03:39 AM
On a 4507R+E chassis with 4712 linecards, I need show which ports are mapped to which ASICs.
Help is appreciated.
Thanks.
Solved! Go to Solution.
03-25-2016 08:09 AM
Have a look at this presentation:-
http://d2zmdbbm9feqrf.cloudfront.net/2014/usa/pdf/BRKARC-3445.pdf
Search for 4712 and you will see the architecture.
4 ASICS with Each ASIC having 2 x 6G to the backplane.
The ports are divided 1-3,4-6,7-9 & 10-12 across the ASICS
Hope this helps
Alex
03-25-2016 08:09 AM
Hope this helps
Alex
04-05-2016 07:24 AM
Thanks much!
