4G LTE Configuration
therealcarbon
Hello all,
I am trying to get my 4g LTE setup working properly, but running into some issues-- below is my config // details on current situation:
version 15.2
chat-script lte"" "AT!CALL" TIMEOUT 60 "OK"
license udi pid CISCO2921/K9 sn FTX1731AMEX
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
access-list 1 permit any
access-list 2 permit 10.2.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
scheduler allocate 20000 1000
Corp4G_1#sh cel 0/0/0 all
Hardware Information
Modem Firmware Version = SWI9200X_03.05.10.02
Modem Firmware built = 2012/02/25 11:58:38
Hardware Version = 10
International Mobile Subscriber Identity (IMSI) = 310410767590990
International Mobile Equipment Identity (IMEI) = 359469040107280
Integrated Circuit Card ID (ICCID) = 89014104277675909901
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) = 15189519432
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = Broadband
Authentication = None
Username:
Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Unknown
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Mobile Country Code (MCC) = 310
Mobile Network Code (MNC) = 410
Packet switch domain(PS) state = Attached
Registration(EMM) state = Registered
Radio Information
Radio power mode = ON
Current RSSI = -53 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
Thanks!
looking at your chat script, I think you might be missing a space. Make sure it looks like this:
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
or use the one you originally configured:
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
Make sure there is a space between lte and the quotes:
lte ""
39 Replies 39
try to remove the 'OK' from your chat script:
or try and 'offload' the cellular configuration to a dialer:
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
no ip address
encapsulation slip
dialer in-band
dialer pool-member 1
dialer-group 1
interface Dialer1
ip nat outside
ip virtual-reassembly im
encapsulation slip (or ppp)
dialer-pool 1
dialer idle-timeout0
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ip nat inside source list 2 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
'Broadband' actually seems to be the correct AT&T APN. Either way, try the chat script below:
chat-script lte"" "AT!CALL1" TIMEOUT 20 "OK"
can you post the full configuration of your router ? You might be missing something else...
Sure---
hostname Corp4G_1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.2.0.1 10.2.0.14
ip dhcp excluded-address 172.16.0.1 172.16.0.10
ip dhcp pool DATA
network 10.2.0.0 255.255.255.192
default-router 10.2.0.1
dns-server 4.4.2.2 8.8.8.8
ip dhcp pool VOICE
network 172.16.0.0 255.255.255.224
default-router 172.16.0.1
no ipv6 cef
controller Cellular 0/0
interface Loopback0
ip address 192.168.1.100 255.255.255.0
ip nat inside
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0.10
description "DATA"
encapsulation dot1Q 10 native
ip address 10.2.0.1 255.255.255.192
ip nat inside
interface GigabitEthernet0/0.20
description "VOICE"
encapsulation dot1Q 20
ip address 172.16.0.1 255.255.255.224
ip nat inside
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Dialer1
ip nat outside
encapsulation slip
shutdown
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
end
try the config below (I have removed the dialer interface and changed access list 2):
hostname Corp4G_1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool DATA
ip dhcp pool VOICE
no ipv6 cef
interface Loopback0
ip nat inside
no ip address
shutdown
no ip address
ip nat inside
duplex auto
speed auto
description "DATA"
ip nat inside
description "VOICE"
ip nat inside
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
no ip http server
access-list 2 permit 10.2.0.0 0.0.0.63
access-list 2 permit 172.16.0.0 0.0.0.31
access-list 2 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
end
no luck on pinging out with that config as well--- some additional output:
Corp4G_1#sh int cellular 0/0/0
Cellular0/0/0 is down, line protocol is down
Hardware is 4G WWAN EHWIC - North America Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Internet address will be assigned dynamically by the network
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 100000 usec,
Encapsulation SLIP, loopback not set
Keepalive not supported
Last input 04:59:21, output 04:59:21, output hang never
Queueing strategy: fifo
Output queue: 0/10 (size/max)
12 packets input, 1259 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
10 packets output, 657 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 carrier transitions
DCD=down DSR=up DTR=down RTS=up CTS=up
Profile Information
PDP Type = IPv4
Username:
Password:
* - Default profile
Data Transmitted = 657 bytes, Received = 1203 bytes
Network Information
Radio Information
Current RSSI = -55 dBm
SIM Status = OK
Error Information
off
lte ""
Thanks so much! That was it!
glad it is solved ! Little things often cause big problems...:)
Corp4G_1#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Jun 19 15:58:34.121: TTY0: pause timer type 1 (OK)
*Jun 19 15:58:34.125: Ce0/0/0 DDR: place call
*Jun 19 15:58:34.125: Ce0/0/0 DDR: Dialing cause ip (s=192.168.1.100, d=8.8.8.8)
*Jun 19 15:58:34.125: Ce0/0/0 DDR: Attempting to dial lte
*Jun 19 15:58:34.125: CHAT0/0/0: Attempting async line dialer script
*Jun 19 15:58:34.125: CHAT0/0/0: Dialing using Modem script: lte"" & System script: none
*Jun 19 15:58:34.125: CHAT0/0/0: process started
*Jun 19 15:58:34.125: CHAT0/0/0: Asserting DTR
*Jun 19 15.:58:34.125: CHAT0/0/0: Chat script lte"" started..
*Jun 19 15:58:39.125: CHAT0/0/0: Chat script lte"" finished, status = Connection timed out; remote host not responding
*Jun 19 15:58:39.125: TTY0/0/0: Line reset by "Async dialer"
*Jun 19 15:58:39.125: Ce0/0/0 DDR: disconnecting call
*Jun 19 15:58:39.125: TTY0/0/0: Modem: (unknown)->HANGUP
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 0 to destroy
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 1 to destroy
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 3 to destroy
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 4 to destroy
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 10 to destroy
*Jun 19 15:58:39.125: TTY0/0/0: no timer type 2 to destroy
*Jun 19 15:58:39.129: TTY0/0/0: dropping DTR, hanging up
*Jun 19 15:58:39.129: tty0/0/0: Modem: HANGUP->(unknown)..
Success rate is 0 percent (0/5)
Still no luck--
The debug output shows that the source of the ping is 192.168.1.100.
Add the following to your access list 2:
Paul Smith
Your profile is inactive. I noticed the APN is called 'Broadband'. Check with your ISP if that is the correct APN. If not edit the profile through the 'controller' command.
Thanks Paul-- all they provided was an APN IP-- how is that inserted?
you might not need that. Try:
Router#cell 0 lte profile create 1
Did they provide CHAP username and password ?
