5 Routers static routing config
Srinivas N
Dear friends,
I wanted to config 5 routers with static routeing in a serial, please configure the below ips
Router A connected to Router B, Router B Connected to Router C, Router C Connected to Router D and Router D connected to Router E
A Router
Fa 0/1 192.168.1.1
s0 10.1.1.1
B Router
Fa 0/1 193.168.1.1
s0 10.1.1.2
s1 20.1.1.1
C Router
Fa 0/1 194.168.1.1
s0 20.1.1.2
s1 30.1.1.1
D Router
Fa 0/1 195.168.1.1
s0 30.1.1.2
s1 40.1.1.1
E Router
Fa 0/1 196.168.1.1
s0 40.1.1.2
Thanks & Regards,
Srinivas.
6 Replies 6
mrdogantr
Router A
ip route 0.0.0.0 0.0.0.0 10.1.1.2
Router E
ip route 0.0.0.0 0.0.0.0 40.1.1.1
Router B
ip route 192.168.1.0 0.0.0.255 10.1.1.1
ip route 194.168.1.0 0.0.0.255 20.1.1.2
ip route 195.168.1.0 0.0.0.255 20.1.1.2
ip route 196.168.1.0 0.0.0.255 20.1.1.2
Router C
ip route 192.168.1.0 0.0.0.255 20.1.1.1
ip route 193.168.1.0 0.0.0.255 20.1.1.1
ip route 195.168.1.0 0.0.0.255 30.1.1.2
ip route 196.168.1.0 0.0.0.255 30.1.1.2
Router D
ip route 192.168.1.0 0.0.0.255 30.1.1.1
ip route 193.168.1.0 0.0.0.255 30.1.1.1
ip route 194.168.1.0 0.0.0.255 30.1.1.1
ip route 196.168.1.0 0.0.0.255 40.1.1.2
hth
Muammer
Thank you Mr.Muammer Dogan,
But, will router A and E will communicate with remaining routers.......?
and i want to communicate each router with each other.
Thanks & Regards,
Srinivas.
No,
Because we are missing some routes:
on B: ip route 30.1.1.0 255.255.255.0 s1
        ip route 40.1.1.0 255.255.255.0 s1
on C: ip route 10.1.1.0 255.255.255.0 s0
on D: ip route 20.1.1.0 255.255.255.0 s0
Regards.
you right, can you change config. 0.0.0.255 --> 255.255.255.0
for example;
ip route 192.168.1.0 255.255.255.0 10.1.1.1
tstamatopoulos
why static routing? when ospf is a much better solution and very easy for your setup is:
Router A:
router ospf 1
router-id 192.168.1.1
redistribute connected subnets
network 10.1.1.0 0.0.0.255
Router B:
router ospf 1
router-id 193.168.1.1
network 20.1.1.0 0.0.0.255
Router C:
router ospf 1
router-id 194.168.1.1
network 30.1.1.0 0.0.0.255
Router D:
router ospf 1
router-id 195.168.1.1
network 40.1.1.0 0.0.0.255
Router E:
router ospf 1
router-id 196.168.1.1
in this config i assumed that you use /24 for peerings between routers, so with this config all prefixes seeing all other prefixes and all works well
Ganesh Hariharan
Dear friends,
A Router
Fa 0/1 192.168.1.1
s0 10.1.1.1
B Router
Fa 0/1 193.168.1.1
s0 10.1.1.2
s1 20.1.1.1
C Router
Fa 0/1 194.168.1.1
s0 20.1.1.2
s1 30.1.1.1
D Router
Fa 0/1 195.168.1.1
s0 30.1.1.2
s1 40.1.1.1
E Router
Fa 0/1 196.168.1.1
s0 40.1.1.2
Always before configuring just draw scehamtic representation to clear cut configuration
For configuring ip address in the router,say for example in router E
int fa0/1
ip address 196.168.1.1 255.255.255.0
no shu
int s0
ip address 40.1.1.2 255.255.255.0
no shu
drop a default route towards router D interface
And same way in Router D for routing towards Router C and Router E subnet
ip address 196.168.1.0 255.255.255.0 40.1.1.2
ip address 194.168.1.0 255.255.255.0 30.1.1.1
Similarly configure for all router !!
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
