5ghz wireless
hi
i need a wireless solution, to connect 2 offices which are around 3 km away.
for TRA approval my equipments should be in 5 ghz band.and the maximum transmit power should not exceed "2watts". i checked with
1310 bridge and 12 dbi external antenna.
but they rejected my application, and that was in 2.4 ghz band.
but when i checked 1400 bridge calculator
i got the information that it cannot be used in middle east.
Please suggest an alternate soulution.
Regds
Binoy.
desai.jaideep
Level 5
Level 5
Try 1230/1240 which are both a/g compliant which means they will work in both 2.4 and 5 GHz band.
I would suggest -20DBi Antennas.
JD
