6500 12.2SXI Support for PBR with Object Tracking
Hi all
I can't seem to find a definitive answer to this on Cisco. We have the need to do PBR on one of our VSS boxes (2 x 6509E). We want to ensure that the next-hop is indeed reachable before sending traffic by using an IP SLA + Object which we incorporate into our route-map thus:
set ip next-hop verify-availability x.x.x.x x track 1
Can anyone confirm that this is supported on the following IOS version:
6509E (VSS)
Advanced IP Services
12.2(33) SXI
Thank you
Jon Marshall
Devlin
Is it because you are runnning VSS that you have the query or is it a general query on which IOS supports it ?
What you want has been supported since 12.2(33)SXH -
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_pi/configuration/12-2sx/iri-pbr-mult-track_ps6017_TSD_Products_Configuration_Guide_Chapter.html#GUID-16C12D82-0E4E-4872-B9DC-D32E3EE871BA
and i don't think features were removed for VSS.
Jon
Jon Marshall
Devlin
Jon
Spot on. Thank you John.
It was actually more of a general query rather than one specifically for VSS.
Cheers
