12-04-2013 11:43 PM - edited 03-04-2019 09:46 PM
Looking for experts here to assist me. I have Cisco Router2811 (A) tunnelling to another Cisco2821 (B) but NATing and connection to internet via ASA Firewall. At Cisco2821 (B) have several VPNs connection and working well but failed with Router A for now. Here are configuration for both routers :
Router A :
crypto isakmp policy 10
encr 3des
authentication pre-share
crypto isakmp key xxxyyyzzz address 211.24.252.54
crypto ipsec transform-set strong esp-3des esp-sha-hmac
crypto map Mal 10 ipsec-isakmp
description == VPN to KL ==
set peer 211.24.252.54
set transform-set strong
match address VPN_to_KL
interface FastEthernet0/0
description == Connection to Internet ==
bandwidth 1536
ip address 218.208.234.6 255.255.255.252
ip access-group public_in in
ip tcp adjust-mss 1405
duplex auto
speed auto
no cdp enable
crypto map Mal
max-reserved-bandwidth 100
ip route 0.0.0.0 0.0.0.0 218.208.234.5
ip access-list extended VPN_to_KL
permit ip 10.41.121.128 0.0.0.127 10.0.0.0 0.255.255.255
ip access-list extended public_in
permit udp host 211.24.252.54 host 218.208.234.6 eq isakmp
permit udp host 211.24.252.54 host 218.208.234.6 eq non500-isakmp
permit esp host 211.24.252.54 host 218.208.234.6
Router B :
crypto isakmp policy 19
encr 3des
group 2
crypto isakmp key xxxyyyzzz address 218.208.234.6
crypto ipsec transform-set Strong esp-3des esp-sha-hmac
crypto map Mal 19 ipsec-isakmp
description == VPN to MSO ==
set peer 218.208.234.6
set transform-set Strong
match address VPN_to_MSO
interface GigabitEthernet0/0
description LINK TO PIX inside2-vpn
ip address 192.0.0.1 255.255.255.252
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
no ip route-cache cef
no ip route-cache
duplex full
speed 100
no cdp enable
crypto map Mal
ip route 10.41.121.128 255.255.255.128 192.0.0.2 name MSO_Internal_Range
ip access-list extended VPN_to_MSO
permit ip 10.0.0.0 0.255.255.255 10.41.121.128 0.0.0.127
Here are debug from Router A :
*Dec 5 11:32:27.203 MYY: ISAKMP:(0): beginning Main Mode exchange
*Dec 5 11:32:27.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:32:27.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Dec 5 11:32:37.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:32:37.203 MYY: ISAKMP (0): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Dec 5 11:32:37.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:32:37.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Dec 5 11:32:47.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:32:47.203 MYY: ISAKMP (0): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Dec 5 11:32:47.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:32:47.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Dec 5 11:32:57.199 MYY: ISAKMP: set new node 0 to QM_IDLE
*Dec 5 11:32:57.199 MYY: ISAKMP:(0):SA is still budding. Attached new ipsec request to it. (local 218.208.234.6, remote 211.24.252.54)
*Dec 5 11:32:57.199 MYY: ISAKMP: Error while processing SA request: Failed to initialize SA
*Dec 5 11:32:57.199 MYY: ISAKMP: Error while processing KMI message 0, error 2.
*Dec 5 11:32:57.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:32:57.203 MYY: ISAKMP (0): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Dec 5 11:32:57.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:32:57.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Dec 5 11:33:07.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:33:07.203 MYY: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Dec 5 11:33:07.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:33:07.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Dec 5 11:33:15.611 MYY: ISAKMP:(0):purging node 920695309
*Dec 5 11:33:15.611 MYY: ISAKMP:(0):purging node -888975984
*Dec 5 11:33:17.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:33:17.203 MYY: ISAKMP (0): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
*Dec 5 11:33:17.203 MYY: ISAKMP:(0): sending packet to 211.24.252.54 my_port 500 peer_port 500 (I) MM_NO_STATE
*Dec 5 11:33:17.203 MYY: ISAKMP:(0):Sending an IKE IPv4 Packet.
mymso01rt2811#
*Dec 5 11:33:25.611 MYY: ISAKMP:(0):purging SA., sa=4969CFB4, delme=4969CFB4co
*Dec 5 11:33:27.203 MYY: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):peer does not do paranoid keepalives.
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):deleting SA reason "Death by retransmission P1" state (I) MM_NO_STATE (peer 211.24.252.54)
*Dec 5 11:33:27.203 MYY: ISAKMP: Unlocking peer struct 0x49B258F8 for isadb_mark_sa_deleted(), count 0
*Dec 5 11:33:27.203 MYY: ISAKMP: Deleting peer node by peer_reap for 211.24.252.54: 49B258F8
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):deleting node 690617595 error FALSE reason "IKE deleted"
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):deleting node -815424110 error FALSE reason "IKE deleted"
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
*Dec 5 11:33:27.203 MYY: ISAKMP:(0):Old State = IKE_I_MM1 New State = IKE_DEST_SA
*Dec 5 11:33:27.231 MYYnf: ISAKMP:(0): SA request profile is (NULL)
*Dec 5 11:33:27.231 MYY: ISAKMP: Created a peer struct for 211.24.252.54, peer port 500
*Dec 5 11:33:27.231 MYY: ISAKMP: New peer created peer = 0x49B258F8 peer_handle = 0x80000B57
*Dec 5 11:33:27.231 MYY: ISAKMP: Locking peer struct 0x49B258F8, refcount 1 for isakmp_initiator
*Dec 5 11:33:27.231 MYY: ISAKMP: local port 500, remote port 500
*Dec 5 11:33:27.231 MYY: ISAKMP: set new node 0 to QM_IDLE
*Dec 5 11:33:27.231 MYY: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 4969CFB4
*Dec 5 11:33:27.231 MYY: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
*Dec 5 11:33:27.231 MYY: ISAKMP:(0):found peer pre-shared key matching 211.24.252.54
*Dec 5 11:33:27.235 MYY: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
*Dec 5 11:33:27.235 MYY: ISAKMP:(0): constructed NAT-T venor-07 ID
*Dec 5 11:33:27.235 MYY: ISAKMP:(0): constructed NAT-T vendor-03 ID
*Dec 5 11:33:27.235 MYY: ISAKMP:(0): constructed NAT-T vendor-02 ID
*Dec 5 11:33:27.235 MYY: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Dec 5 11:33:27.235 MYY: ISAKMP:(0):Old State = IKE_READY New State = IKE_I_MM1
What is the possible problem?
Thanks!!!
12-05-2013 03:24 AM
From that debug it looks as if Router A is not getting a response from Router B. Are you able to run debug on Router B and post it? Does Router B even receive any traffic relating to this tunnel?
