6500 CPU going high when IPV6 enabling at end device
Jerald Simon M.
6500 CPU going high when IPV6 enabling end device like LAPTOP/PC , is there any thing we can do with 6500 switch.
johnd2310
Level 8
Level 8
HI,
What process is causing high cpu on the 6500? You will need to determine what traffic the end devices are sending by capturing some traffic using wireshark.
John
**Please rate posts you find helpful**
