What can I do... about confreg-register
Soon Kwan Kwon
Hello guys.
I have two Routers (2801, 2811)
I changed the confreg-register from 0x2102  to 0x2132 by my mistake.
But it is not working properly.
When I connected to the routers with PC, in the PuTTY, its font was broken down.
So, I searched it and then I found that the answer was to be setting the console speed more than 9600.
I did following that steps.
However, I recognized another problem was present...
After I configured register 0x2102, but It was changed 0x2122...
Continuously I changed register, but continuously remained 0x2122.
The point is .. Why did it change continuously 0x2122???
Please teach me what can I do to fix it!
2 Accepted Solutions
Leo Laohoo
Eject the CF from the router(s).  Reboot the router into ROMmon.  Change the config-registry value to the correct ones from ROMmon:  config-register 0x2102.
Once done, insert the CF and reboot the router once more.
Glad to see it's working.
May I ask if you can mark this thread as "Answered"?
5 Replies 5
Leo Laohoo
Thank you for replying comment.
I tried your comment, but it was also broken down FONT...
plz show below photo!ㅠㅠ
AHAHAHAH
You're Right !!
I finally completed this problem !
Thank you so much~^^
OK I just clicked ^^!
I ask you to reply my another question...
https://supportforums.cisco.com/discussion/12504576/i-also-have-problem-about-cisco-2801
plz show!!ㅠ_ㅠ
