01-13-2012 12:40 AM - edited 03-04-2019 02:53 PM
Can someone help me in what is the protocol used between both sup engine ? and how both sup engine in 6500 communciate to have replicate routing information ?
Solved! Go to Solution.
01-13-2012 05:41 AM
Hi there,
if you refer to communication between redundant supervisors in the same chassis they use the EoBC (Ethernet out of cand channel) and they get synchronized by means of a protocol called SLP (Serial link protocol).
No need to study that as it is specific to Cat6500/7600 architecture. I doubt you would find useful information anyway.
Other internal protocol used for management (going through eobc) are:
SCP (to communicate from Sup to linecards - used to program TCAMs)
IPC (to communicate to IOS CPU)
RPC (to communicate between RP and SP using IPC)
etc.
Riccardo
01-13-2012 04:54 AM
It sounds like you're talking about VSL. You will need to configure a VSL link to setup this replication.
http://inetpro.org/wiki/Virtual_Switch_System
Hope that helps.
01-13-2012 05:41 AM
Hi there,
etc.
Riccardo
01-15-2012 04:00 AM
Thanks Riccardo , Great information
01-15-2012 04:01 AM
Thanks John , I am taling about same chasies sup engine , Thanks any way for the help
