6503 switch or 7201 router ?
mcroft
I am looking at running MPLS from from one datacentre to the other (we have a layer2 interconnect and can run jumbo frames)
I need about 70 access ports (each in a seperate VRF) at the new datacentre
I am looking at :
2x 6503'-Es with sup720-3B and a 48x port linecard
or
2x 7201 router with 2x 2960-S layer 2 access switches.
I am a little confused about which option would be best.
Any help apprecaited.
Matt
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
"Best" option would likely depend on other features that might be necessary or useful.  The 6500 offers much higher performance than the 7200, while the 7200 offers more features.
PS:
If you go with the 6500, you might also consider using just one chassis, with (e.g. 6504) or without (6503) a 2nd sup.  7600 series might also be considered as its feature set is more routing oriented.
