One router with two WAN connections
majed.balsharaf
Hello
  I have one more scenario, at my branch office, I am having one router with my Cloud network and internet on this interfaces
Router
int f0/0
des Connected to LAN
ip add 10.x.x.254 255.255.255.0
int f0/1
des Connected to Internet
ip add 62.x.x.21 255.255.255.252
int f0/1/0
Connected to Cloud
ip add 172.16.13.146 255.255.255.252
ip route 0.0.0.0 62.149.108.22
ip route 10.0.0.0 255.0.0.0 172.x.x.145
dhcp pool ABC
network 10.x.x.x 255.255.255.0
default-router 10.x.x.254
How to generate the traffic  for both cloud and internet
milan.kulik
Level 10
Level 10
is there any FW involved to protect your Internet connection?
If not, you will need to configure NAT on your router to be able to connect your users to the Internet effectively.
HTH,
Milan
Im having NAT configuration for
f0/0 and f0/1
my new interface is f0/1/0 which is connecting to my cloud
where's the problem then?
You've got your route to the cloud configured:
Does the cloud know how to route to your site ( 10.x.x.254)?
If yes, everything should be working OK.
BR,
Milan
