6509 Auto QoS cisco softphone
Chris Lane
Running 122-33.SXH1 IOS
Line cards are ws-x6148 rj45V
trying to mimic a 3750 PS cisco softphone qos implementation but the 6500 does not seem to support the Auto Qos cisco softphone feature.
Wondering if this is an IOS issue or the Line cards themselves not capable? If so any recommendations?
Sample Config of 3750:
policy-map AutoQoS-Police-SoftPhone
  class AutoQoS-VoIP-RTP-Trust
   set dscp ef
    police 320000 8000 exceed-action policed-dscp-transmit
  class AutoQoS-VoIP-Control-Trust
   set dscp cs3
    police 32000 8000 exceed-action policed-dscp-transmit
interface FastEthernet1/0/1
switchport access vlan X
service-policy input AutoQoS-Police-SoftPhone
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
auto qos voip cisco-softphone
Thank you
Chris
Calin C.
Level 5
Level 5
Hello Chris.
The port you are trying to apply the command is a Layer 2 port but any chance?
Look what is happening when I try to enable it on L2 ports on C6506:
R8-C6506#sh int gi3/1 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
R8-C6506(config)#int gi3/1
R8-C6506(config-if)#auto qos voip cisco-softphone
Please convert the port as routed port, then issue the auto qos command
If it's not a L2 port but and L3, what kind of error message do you get?
I can apply it without any problems on a router port in a C6506 with 12.2(33)SXH, but with X6516-GBIC, not x6148
Please let me know if this helps!
Calin
