6509 rommon mode issue
rishad ahammed
hi,   my cisco 6509 switch is going to rommon mode on every rebooting. And I have to put the boot command manually to recover from rommon mode. I put my IOS image in external memory card, since I dont have enough space in internal flash.    And the external flash is reffered to as disk0: in the switch.  To solve this issue I tried to put boot variable But I failed. Because in the boot system command I have only option to flash not to disk0: . So can any one please tell me how to set this boot variable or how to fix this rommon mode issue. I have tried the following command to put the boot variable.
   boot system flash disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin.
Hello
Sh version
Sh boot
Sh file systems
res
Paul
Kind Regards
Paul
Thank you for your reply, here is the show commands as you suggested
Router#sho vers
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 11-Mar-14 04:53 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
 Router uptime is 5 days, 15 hours, 19 minutes
Uptime for this control processor is 5 days, 15 hours, 20 minutes
Time since Router switched to active is 5 days, 15 hours, 19 minutes
System returned to ROM by  power cycle at 06:45:00 UTC Fri Jun 20 2014 (SP by power on)
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-NEB-A (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID FOX104504PA
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
1 Virtual Ethernet interface
144 FastEthernet interfaces
66 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
#sho file systems
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     ro   flexwan-fpd:
      65536000      65247408     flash     rw   bootflash:
*    256540672     137826304      disk     rw   disk0:#
     255799296     112422912      disk     rw   disk1:#
      65536000      65536000     flash     rw   sup-bootflash:
     108942482             0    opaque     ro   sup-microcode:
             0     184070176    opaque     wo   sup-image:
        129004        129004     nvram     rw   const_nvram:
       1964024       1948315     nvram     rw   nvram:
             -             -    opaque     rw   null:
             -             -    opaque     ro   tar:
             -             -   network     rw   tftp:
             -             -    opaque     wo   syslog:
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
Router#
Router#sho boot
BOOT variable = disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin,12;bootflash:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin,1;sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable =
Standby not ready to show bootvar
rishad ahammed
can any one please help me on this
