Cisco 7606 -- CPU Utilisation High Due To ARP Input Process -- High ARP Flood -- Layer 2 Loop
Nishant Kumar
We are facing issue with Cisco 7606 Router Utilization going High 99% or, even crashing due to High ARP Input Process. Even our traffic fluctuated few times during this High CPU.
R1#sh    sh proc cpu sorted
CPU utilization for five seconds: 100%/36%; one minute: 99%; five minutes: 99%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  12   668200272  4130695785          0 53.53% 52.79% 42.77%   0 ARP Input
  72    55456108   223377939        248  8.92%  8.91%  8.38%   0 HSRP Common
 380    59365092    36382257       1631  0.15%  0.08%  0.09%   0 HIDDEN VLAN Proc
  29    17875596   139450515        128  0.15%  0.02%  0.00%   0 IPC Seat Manager
 486    92359492  1307802877         70  0.07%  0.06%  0.04%   0 Port manager per
 214    26186336   415808869         62  0.07%  0.04%  0.02%   0 ADJ resolve proc
 367       82696   103827990          0  0.07%  0.00%  0.00%   0 FM core
 321    27696224   113208002        244  0.07%  0.07%  0.07%   0 CEF: IPv4 proces
 159      253224    72766316          3  0.07%  0.01%  0.00%   0 Per-Second Jobs
 178     2630620    22998317        114  0.07%  0.00%  0.00%   0 dwdm RPC RP proc
 157      149948    14554314         10  0.07%  0.00%  0.00%   0 Compute load avg
R1#sh proc cpu hist
                    11111          11111     11111          11111
      999999999999990000099999999990000099999000009999999999000009
  100 **********************************************************
   90 **********************************************************
   80 **********************************************************
   70 **********************************************************
   60 **********************************************************
   50 **********************************************************
   40 **********************************************************
   30 **********************************************************
   20 **********************************************************
   10 **********************************************************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      1111
      000099999999999999999999999999999999999999999999999999999999
 --More--               000099999999999999999999999999999999999999999999999999999999
  100 ##########################################################
   90 ##########################################################
   80 ##########################################################
   70 ##########################################################
   60 ##########################################################
   50 ##########################################################
   40 ##########################################################
   30 ##########################################################
   20 ##########################################################
   10 ##########################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
Defined scheduler for low priority process, so that we can run commands.
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#scheduler allocate 3000 1000
R1(config)#
This router is having HSRP configuration and second router was having even higher CPU utilisation and we were not even able to login to it properly.
Almost all HSRP stanby was showing as unknown.
-R1#sh standby br
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Gi1/6.852   83   110 P Active  local           unknown         172.19.129.190
Gi1/6.853   84   110 P Active  local           unknown         172.19.145.190
Gi1/6.854   85   110 P Active  local           unknown         172.19.161.190
Gi1/6.855   86   110 P Active  local           unknown         172.19.177.190
Gi1/7.1367  47   110 P Active  local           unknown         172.34.213.165
Gi1/7.1368  48   110 P Active  local           unknown         172.34.212.150
Gi1/7.1369  49   110 P Active  local           unknown         172.34.228.150
Gi1/7.1370  50   110 P Active  local           unknown         172.34.244.150
Gi1/7.1371  51   110 P Active  local           unknown         172.34.192.94
Gi1/7.1372  52   110 P Active  local           unknown         172.34.208.94
Gi1/7.1373  53   110 P Active  local           unknown         172.34.224.94
Gi1/7.1374  54   110 P Active  local           unknown         172.34.240.94
Gi1/7.1423  103  110 P Active  local           unknown         172.34.196.206
Gi1/7.1424  104  110 P Active  local           unknown         172.34.212.206
Gi1/7.1425  105  110 P Active  local           unknown         172.34.228.206
Gi1/7.1426  106  110 P Active  local           unknown         172.34.244.206
Gi1/7.1427  107  110 P Active  local           unknown         172.34.193.62
Gi1/7.1428  108  110 P Active  local           unknown         172.34.209.62
Gi1/7.1429  109  110 P Active  local           unknown         172.34.225.62
Disabled proxy-ARP globally hoping CPU ARP process to go down, but no effect.
Suspected broadcasts storm/loop from connected VLAN segments.
R1#sh arp summary
Total number of entries in the ARP table: 4757.
Total number of Dynamic ARP entries: 2877.
Total number of Incomplete ARP entries: 22.
Total number of Interface ARP entries: 930.
Total number of Static ARP entries: 1.
Total number of Alias ARP entries: 0.
Total number of Simple Application ARP entries: 0.
Total number of Application Alias ARP entries: 927.
Total number of Application Timer ARP entries: 0.
R1#sh int switching
GigabitEthernet1/1 "To RNC-NPGE8-GE0"
          Throttle count          0
                   Drops         RP          1         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs          0      Drops          0
    NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet1/2 "To RNC-NPGE8-GE1"
    All statistics for this interface are zero.
GigabitEthernet1/3 "To RNC-NPGE7-GE0(2)"
GigabitEthernet1/4 "To RNC-NPGE7-GE1(2)"
          Throttle count          0
                   Drops         RP          2         SP          0
             SPD Aggress       Fast          0
Interface GigabitEthernet1/5 is disabled
 --More--
GigabitEthernet1/6 "Towards NodeB"
          Throttle count         17
                   Drops         RP         34         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    8984644      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process      18071    1699474 1038652735 135024790450
            Cache misses          0          -          -          -
                    Fast        772      78597        360      27232
               Auton/SSE 66476795187 6333899252909 67494231497 13239901988015
    Protocol  ARP
                 Process    8868769  532126140   10208225  979989600
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
 --More--                   Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process          0          0    1209529 1154012765
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process    2364492  151327488          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet1/7
          Throttle count          2
                   Drops         RP         29         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 1265302887      Drops          1
    Protocol  IP
 --More--                          Process 1207101843 113048448423 9160328458 1190842417144
                    Fast       2555     324546       1055      94046
               Auton/SSE 739269360229 71261339904258 667523378934 199582675518415
    Protocol  ARP
                 Process   57835050 3470103000   89252506 8568240576
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     935887  916061727
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet1/8
          Throttle count      97234
 --More--                            Drops         RP   30506133         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 1271133035      Drops       1377
    Protocol  IP
                 Process 1211688606 113479732827 10045716157 1305942833734
                    Fast         27       2394       1093     106669
               Auton/SSE 750093711497 71273621295681 666022899242 181907733648456
    Protocol  ARP
                 Process   58924254 3535455240   79556872 7637459712
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     894784  850735416
 --More--                     Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process         48       3622          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet1/9
          Throttle count         99
                   Drops         RP       6711         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 6430322124      Drops         69
    Protocol  IP
                 Process 6373687183 596891003390 9267445191 1204767554066
 --More--                             Fast        229      21535       4465     372114
               Auton/SSE 781419993066 74539807071219 683692000098 191383475495560
    Protocol  ARP
                 Process   56215319 3372919140  125221691 12021282336
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     909183  877180664
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet1/10
          Throttle count          6
                   Drops         RP       1592         SP          0
 --More--                      SPD Aggress       Fast          0
            SPD Priority     Inputs 1534561971      Drops          4
    Protocol  IP
                 Process 1479818364 138583588542 7924898414 1030236629520
                    Fast       1414     133530      21681    1624118
               Auton/SSE 478101751435 45953422496680 443076946931 124379634383997
    Protocol  ARP
                 Process   53405334 3204320040   72118358 6923362368
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     884427  830514902
                    Fast          0          0          0          0
 --More--                        Auton/SSE          0          0          0          0
    Protocol  Other
                 Process        221      22289          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Interface GigabitEthernet1/11 is disabled
GigabitEthernet1/12
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    5390933      Drops          0
    Protocol  IP
                 Process    5391015 1416067930    5410624 1613160355
 --More--                             Fast         10       1140        225      16017
               Auton/SSE      28343    2211181 7286967271 4339101877275
    Protocol  ARP
                 Process       2839     170344       2886     277072
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process     702075  294871500     702075  316341504
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Interface GigabitEthernet1/13 is disabled
Interface GigabitEthernet1/14 is disabled
GigabitEthernet1/15 "To -RNC-NPGE10-GE0"
 --More--                   Throttle count          0
                   Drops         RP       2545         SP          0
             SPD Aggress       Fast          0
GigabitEthernet1/16 "To -RNC-NPGE10-GE1"
Interface GigabitEthernet1/17 is disabled
Interface GigabitEthernet1/18 is disabled
Interface GigabitEthernet1/19 is disabled
Interface GigabitEthernet1/20 is disabled
Interface GigabitEthernet1/21 is disabled
Interface GigabitEthernet1/22 is disabled
Interface GigabitEthernet1/23 is disabled
 --More--
Interface GigabitEthernet1/24 is disabled
GigabitEthernet2/1 "To ESA-24(Primry)Eth-0 for O&M"
          Throttle count        196
                   Drops         RP        403         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs  262141511      Drops          0
    Protocol  IP
                 Process  268331200 25241584261  260660005 33856311131
                    Fast   28081214 2491588878   15910212 1152718000
               Auton/SSE 2432834899 606028315324 2312615050 246993220389
    Protocol  ARP
                 Process     164509    9870540     111651   10718496
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
 --More--
GigabitEthernet2/2 "To ESA-24(Secondry)Eth-1 for O&M"
          Throttle count      52388
                   Drops         RP   40453471         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 10848535937      Drops      52272
    Protocol  IP
                 Process 10803976604 1015050540468 10678388714 1388190250136
                    Fast       1911     177849       1276     112512
               Auton/SSE 336628119334 33635423501532 318978917157 89781137959620
    Protocol  ARP
                 Process   43482684 2608961040   53400453 5126443488
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
 --More--             Protocol  Other
                 Process        319      27562          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/3 "To OSS_P-2-P"
          Throttle count          8
                   Drops         RP         17         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    1499744      Drops          0
    Protocol  IP
                 Process  146998556 40751438635  165454359 60818956931
                    Fast     349133  217433889         37      12387
               Auton/SSE  694136581 167140014065  751137120 593865172332
    Protocol  ARP
                 Process       5210     312600       5376     516096
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process    1207542  466111302    1208019  908024549
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/4 ***** ESA-24(Primry)Eth-0(-2) ****
    Protocol  CDP
                 Process          0          0     949929  707604148
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
 --More--             NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet2/5 "Towards NodeB"
          Throttle count      37439
                   Drops         RP   56027113         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 17929929096      Drops      35323
    Protocol  IP
                 Process 16447980923 1544583644733 14121248211 1835761384008
                    Fast       5814     575101     450167   32867731
               Auton/SSE 2392531330675 241626193065575 2035056202817 588477685543833
    Protocol  ARP
                 Process  572712369 34362742436  558232707 53590339872
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
 --More--             Protocol  CDP
                 Process          0          0    1181002 1139517924
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process        182      18514          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/6 Towards-NodeB
          Throttle count       6064
                   Drops         RP      72691         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 8664893746      Drops        158
    Protocol  IP
                 Process 8591207041 804610123695 11968599318 1555917403533
                    Fast       1185      85619    4433632  315992158
               Auton/SSE 1217214338506 125944542707179 1061983543941 326654931730119
    Protocol  ARP
                 Process   67855000 4071300000  100254672 9624448512
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0    1110422 1090291317
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
 --More--                          Process        197      19036          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/7
          Throttle count       9073
                   Drops         RP    2438456         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 14951544826      Drops       3128
    Protocol  IP
                 Process 10860179490 1018001152549 8367171452 1087731954444
                    Fast       1727     228123       1089      91571
               Auton/SSE 666450949333 67213840255393 551735662180 163801189371137
    Protocol  ARP
 --More--                          Process 4063410664 243804639840  616500448 59184043008
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     998533  995298276
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          2        120          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/8
          Throttle count      10339
                   Drops         RP    3781143         SP          0
 --More--                      SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 6316146783      Drops       4879
    Protocol  IP
                 Process 6215051438 581957224058 6024793819 783158699527
                    Fast         12        879     574882  325094639
               Auton/SSE 1318790195510 132937773420998 1084263713776 332292082208893
    Protocol  ARP
                 Process   87141823 5228509380   98126316 9420126336
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     946191  930141527
 --More--                             Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/9
          Throttle count       8351
                   Drops         RP    6392365         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 2405226535      Drops       8043
    Protocol  IP
                 Process 2131392568 200005010556 7946243483 1033011292113
                    Fast         48       4452      47976   62318914
               Auton/SSE 456158233919 46197222234445 408848321059 119474830140709
    Protocol  ARP
                 Process  207483024 12448984440  205192973 19698525408
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     990695  987548604
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet2/10
          Throttle count        612
                   Drops         RP     476011         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 4052715263      Drops        506
    Protocol  IP
                 Process 3989707312 373708189202 5027090956 653521627216
                    Fast         50       4403      54860   69067357
 --More--                        Auton/SSE 1052068106702 106517213601075 914208428646 258485381463575
    Protocol  ARP
                 Process   62201866 3732111960   65951880 6331380480
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     970775  966116235
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
TenGigabitEthernet2/11 "Towards Router-2 tenGig2/11 for HSRP"
GigabitEthernet3/1
          Throttle count        993
 --More--                            Drops         RP     350484         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 8331321189      Drops        719
    Protocol  IP
                 Process 8292199677 776575541729 10268474281 1334901371862
                    Fast       2644     257476        911      97470
               Auton/SSE 272940576253 28645368342005 292289080535 84659972777221
    Protocol  ARP
                 Process   39044041 2342642460   42363944 4066938624
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     698684  314128386
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process        395      34441          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet3/2
          Throttle count       8485
                   Drops         RP    6133597         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 1698532595      Drops       4822
    Protocol  IP
                 Process 1582077712 148133142704 5311020195 690432511786
                    Fast        449      44373    1528541  174898176
 --More--                        Auton/SSE 1103452799680 109265165928865 854252756746 256733637846785
    Protocol  ARP
                 Process   58420387 3505223220   64602490 6201839040
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0     698690  314129965
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process         56       5392          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
 --More--
GigabitEthernet3/3
          Throttle count      21726
                   Drops         RP   25626468         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 7907583197      Drops      21711
    Protocol  IP
                 Process 7856865288 735631039363 6623310216 860931278526
                    Fast        703      69398      10620     984799
               Auton/SSE 169839188165 18130226559561 170875861644 52924101076420
    Protocol  ARP
                 Process   47516331 2850979860   56341990 5408831040
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
                 Process          0          0     341638  155244288
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process        121      11539          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet3/4
          Throttle count      41827
                   Drops         RP   60675191         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 5735650093      Drops      35987
    Protocol  IP
 --More--
-R1#sh int switching | i Throttle|Ethernet
          Throttle count          0
          Throttle count          0
          Throttle count         17
GigabitEthernet1/7
          Throttle count          2
GigabitEthernet1/8
GigabitEthernet1/9
          Throttle count         99
GigabitEthernet1/10
          Throttle count          6
GigabitEthernet1/12
          Throttle count          0
          Throttle count        196
          Throttle count          8
          Throttle count      37453
          Throttle count       6064
GigabitEthernet2/7
          Throttle count       9073
 --More--         GigabitEthernet2/8
GigabitEthernet2/9
          Throttle count       8351
GigabitEthernet2/10
          Throttle count        612
GigabitEthernet3/1
          Throttle count        993
GigabitEthernet3/2
          Throttle count       8485
GigabitEthernet3/3
GigabitEthernet3/4
          Throttle count      41831
Interface GigabitEthernet3/5 is disabled
Interface GigabitEthernet3/6 is disabled
Interface GigabitEthernet3/7 is disabled
Interface GigabitEthernet3/8 is disabled
Interface GigabitEthernet3/9 is disabled
Interface GigabitEthernet3/10 is disabled
Interface TenGigabitEthernet3/11 is disabled
Interface GigabitEthernet5/1 is disabled
 --More--         Interface GigabitEthernet5/2 is disabled
          Throttle count        337
          Throttle count        316
          Throttle count        396
          Throttle count        337
          Throttle count          0
          Throttle count          0
          Throttle count          0
          Throttle count          0
          Throttle count         16
          Throttle count         21
          Throttle count         15
          Throttle count         17
          Throttle count         11
          Throttle count          0
          Throttle count          0
          Throttle count         17
GigabitEthernet1/7
          Throttle count          2
GigabitEthernet1/8
GigabitEthernet1/9
          Throttle count         99
GigabitEthernet1/10
          Throttle count          6
GigabitEthernet1/12
          Throttle count          0
          Throttle count        196
          Throttle count          8
          Throttle count      37460
          Throttle count       6064
GigabitEthernet2/7
          Throttle count       9073
GigabitEthernet2/9
          Throttle count       8351
GigabitEthernet2/10
          Throttle count        612
GigabitEthernet3/1
          Throttle count        993
GigabitEthernet3/2
          Throttle count       8485
GigabitEthernet3/3
GigabitEthernet3/4
          Throttle count      41840
          Throttle count        337
          Throttle count        316
          Throttle count        396
          Throttle count        337
          Throttle count          0
          Throttle count          0
          Throttle count          0
          Throttle count          0
          Throttle count         16
          Throttle count         21
          Throttle count         15
          Throttle count         17
          Throttle count         11
-R1#sh int switching | i Throttle|Ethernet2/5
          Throttle count          0
          Throttle count          0
          Throttle count         17
          Throttle count          2
          Throttle count         99
          Throttle count          6
          Throttle count          0
          Throttle count          0
          Throttle count        196
          Throttle count          8
          Throttle count      37465
          Throttle count       6064
          Throttle count       9073
          Throttle count       8351
          Throttle count        612
          Throttle count        993
          Throttle count       8485
 --More--         -R1#[AA A
-R1#sh int gi2/5 switching
          Throttle count      37468
                   Drops         RP   56028163         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 17929956472      Drops      35323
    Protocol  IP
                 Process 16448007163 1544586093375 14121357474 1835775588198
               Auton/SSE 2392565413119 241629434240291 2035083627647 588485993305470
    Protocol  ARP
                 Process  572712433 34362746276  558256814 53592654144
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0    1181007 1139520199
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
          Throttle count      37472
                   Drops         RP   56028413         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs 17929958896      Drops      35323
    Protocol  IP
                 Process 16448009472 1544586307667 14121366558 1835776769118
               Auton/SSE 2392568576867 241629732349772 2035085955749 588486688177901
    Protocol  ARP
                 Process  572712445 34362746996  558258770 53592841920
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
 --More--
-R1#sh int gi  3/5    i2/5
GigabitEthernet2/5 is up, line protocol is up (connected)
  Hardware is X40G 1Gb 802.3, address is 588d.09b5.8740 (bia 588d.09b5.8740)
  Description: "Towards NodeB"
  MTU 9000 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 50/255, rxload 19/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is LX
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 46/75/56028689/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 76296000 bits/sec, 100372 packets/sec
  5 minute output rate 197057000 bits/sec, 81530 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     2410612348456 packets input, 243411854214908 bytes, 7 no buffer
     Received 17983634914 broadcasts (0 IP multicasts)
 --More--              0 runts, 0 giants, 37475 throttles
     333 input errors, 146 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     2100173434827 packets output, 604413496773294 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
-R1#sh int gi2/5 | in     broadcasts|input
  Last input 00:00:01, output 00:00:00, output hang never
  5 minute input rate 76136000 bits/sec, 100264 packets/sec
     2410620121916 packets input, 243412589799353 bytes, 7 no buffer
     Received 17983639906 broadcasts (0 IP multicasts)
-R1#sh int gi2/5 | i broadcasts|input
  5 minute input rate 76236000 bits/sec, 100345 packets/sec
     2410622199407 packets input, 243412788539974 bytes, 7 no buffer
     Received 17983643928 broadcasts (0 IP multicasts)
  5 minute input rate 76046000 bits/sec, 100058 packets/sec
     2410625081019 packets input, 243413063243036 bytes, 7 no buffer
R1#sh int gi2/5
     reliability 255/255, txload 55/255, rxload 18/255
  Clock mode is auto
  Input queue: 58/75/56033013/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 72864000 bits/sec, 95610 packets/sec
  5 minute output rate 217369000 bits/sec, 78319 packets/sec
     2410719033721 packets input, 243421982333313 bytes, 7 no buffer
     Received 17983721742 broadcasts (0 IP multicasts)
 --More--              0 runts, 0 giants, 37561 throttles
     2100261309807 packets output, 604442668529126 bytes, 0 underruns
-R1#sh int  | i Ethernet|queue
GigabitEthernet1/1 is up, line protocol is up (connected)
  Input queue: 0/2000/1/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/2 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/3 is up, line protocol is up (connected)
GigabitEthernet1/4 is up, line protocol is up (connected)
  Input queue: 0/2000/2/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/5 is administratively down, line protocol is down (disabled)
GigabitEthernet1/6 is up, line protocol is up (connected)
  Input queue: 0/75/34/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/7 is up, line protocol is up (connected)
 --More--           Input queue: 131/75/29/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/8.1572 is up, line protocol is up (connected)
 --More--         GigabitEthernet1/8.1573 is up, line protocol is up (connected)
GigabitEthernet1/9 is up, line protocol is up (connected)
  Input queue: 5/75/6711/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/9.1360 is up, line protocol is up (connected)
 --More--         GigabitEthernet1/9.1361 is up, line protocol is up (connected)
GigabitEthernet1/9.1622 is up, line protocol is up (connected)
 --More--         GigabitEthernet1/10 is up, line protocol is up (connected)
  Input queue: 85/75/1592/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/12 is up, line protocol is up (connected)
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/15 is up, line protocol is up (connected)
  Input queue: 0/2000/2545/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/16 is up, line protocol is up (connected)
GigabitEthernet1/17 is administratively down, line protocol is down (disabled)
GigabitEthernet1/18 is administratively down, line protocol is down (disabled)
GigabitEthernet1/19 is administratively down, line protocol is down (disabled)
GigabitEthernet1/20 is administratively down, line protocol is down (disabled)
GigabitEthernet1/21 is administratively down, line protocol is down (disabled)
 --More--         GigabitEthernet1/22 is administratively down, line protocol is down (disabled)
GigabitEthernet1/23 is administratively down, line protocol is down (disabled)
GigabitEthernet1/24 is administratively down, line protocol is down (disabled)
GigabitEthernet2/1 is up, line protocol is up (connected)
  Input queue: 2/75/403/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet2/1.179 is up, line protocol is up (connected)
GigabitEthernet2/2 is up, line protocol is up (connected)
  Input queue: 71/75/40453471/0 (size/max/drops/flushes); Total output drops: 0
 --More--
-R1#sh int | i Ethernet|queuegi2/5
  Clock mode is auto
  Input queue: 26/75/56034548/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 72426000 bits/sec, 94651 packets/sec
  5 minute output rate 218269000 bits/sec, 77885 packets/sec
     2410737557336 packets input, 243423760832286 bytes, 7 no buffer
     Received 17983742142 broadcasts (0 IP multicasts)
 --More--
-R1#
-R1#
-R1#sh int gi2/5
     reliability 255/255, txload 56/255, rxload 18/255
  Clock mode is auto
  Input queue: 65/75/56034717/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 72827000 bits/sec, 94890 packets/sec
  5 minute output rate 220698000 bits/sec, 78017 packets/sec
     2410741510056 packets input, 243424147586617 bytes, 7 no buffer
 --More--
-R1#sh int gi2/5
  Clock mode is auto
  Input queue: 184/75/56035131/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 72649000 bits/sec, 94556 packets/sec
  5 minute output rate 221547000 bits/sec, 78052 packets/sec
     2410744217321 packets input, 243424410370468 bytes, 7 no buffer
     Received 17983747269 broadcasts (0 IP multicasts)
Tried to analyse different counters but I was not able to analyse different counters or, conclude anything from interface stats.(quite possible I might have missed something).
R1#sh sto      show interfaces counters storm-control
Port         UcastSupp %     McastSupp %     BcastSupp %  TotalSuppDiscards
Gi1/1             100.00            0.10            0.10                  0
Gi1/2             100.00            0.10            0.10                  0
Gi1/3             100.00            0.10            0.10                  0
Gi1/4             100.00            0.10            0.10                  0
Gi1/5             100.00            0.10            0.10                  0
Gi1/6             100.00            0.10            0.10                  0
Gi1/7             100.00            0.10            0.10          262632978
Gi1/8             100.00            0.10            0.10          159354578
Gi1/9             100.00            0.10            0.10          411450004
Gi1/10            100.00            0.10            0.10          377447405
Gi1/11            100.00          100.00          100.00                  0
Gi1/12            100.00          100.00          100.00                  0
Gi1/13            100.00          100.00          100.00                  0
Gi1/14            100.00          100.00          100.00                  0
Gi1/15            100.00            0.10            0.10                  0
Gi1/16            100.00            0.10            0.10                  0
Gi1/17            100.00          100.00          100.00                  0
Gi1/18            100.00          100.00          100.00                  0
Gi1/19            100.00          100.00          100.00                  0
Gi1/20            100.00          100.00          100.00                  0
Gi1/21            100.00          100.00          100.00                  0
 --More--
Gi1/22            100.00          100.00          100.00                  0
Gi1/23            100.00          100.00          100.00                  0
Gi1/24            100.00          100.00          100.00                  0
Gi2/1             100.00            0.10            0.10                  0
Gi2/2             100.00            0.10            0.10                  0
Gi2/3             100.00          100.00          100.00                  0
Gi2/4             100.00            0.10            0.10                518
Gi2/5             100.00            0.10            0.10                  0
Gi2/6             100.00            0.10            0.10                  0
Gi2/7             100.00            0.10            0.10                  0
Gi2/8             100.00            0.10            0.10                  0
Gi2/9             100.00            0.10            0.10                  0
Gi2/10            100.00            0.10            0.10                  0
Te2/11            100.00           50.00           50.00                  0
Gi3/1             100.00            0.10            0.10                  0
Gi3/2             100.00            0.10            0.10                  0
Gi3/3             100.00            0.10            0.10                  0
Gi3/4             100.00            0.10            0.10                  0
Gi3/5             100.00          100.00          100.00                  0
Gi3/6             100.00          100.00          100.00                  0
Gi3/7             100.00          100.00          100.00                  0
Gi3/8             100.00          100.00          100.00                  0
Gi3/9             100.00          100.00          100.00                  0
 --More--
Gi3/10            100.00          100.00          100.00                  0
Te3/11            100.00          100.00          100.00                  0
Gi5/1             100.00          100.00          100.00                  0
Gi5/2             100.00          100.00          100.00                  0
-R1#
-R1#show interfaces gig3/4 counters storm-control
-R1#show interfaces counters storm-control counters
 --More--
 --More--
 --More--
-R1#show interfaces counters storm-control               s ?
  errors         Show interface error counters
  etherchannel   Show interface etherchannel counters
  module         Limit display to interfaces on module
  protocol       interface protocol counters
  storm-control  Show interface storm control discard counters
  trunk          Show interface trunk counters
  |              Output modifiers
  <cr>
-R1#show interfaces counters errors
Port        Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize OutDiscards
Gi1/1               0          0          0          1         0           0
Gi1/2               0          0          0          0         0           0
Gi1/3               0          0          0          0         0           0
Gi1/4               0          0          0          2         0           0
Gi1/5               0          0          0          0         0           0
Gi1/6               0          0          0          0         0           0
Gi1/7               0          0          0          0         0           0
Gi1/8               0          0          0          0         0           0
Gi1/9               0          1          0          5         0           0
Gi1/10              0          0          0          0         0           0
Gi1/11              0          0          0          0         0           0
Gi1/12              0          0          0          0         0           0
Gi1/13              0          0          0       9686         0           0
Gi1/14              0          0          0          0         0           0
Gi1/15              0          0          0       2545         0           0
Gi1/16              0          0          0          0         0           0
Gi1/17              0          0          0          0         0           0
Gi1/18              0          0          0          0         0           0
Gi1/19              0          0          0          0         0           0
Gi1/20              0          0          0          0         0           0
Gi1/21              0          0          0          0         0           0
 --More--
Gi1/22              0          0          0          0         0           0
Gi1/23              0          0          0          0         0           0
Gi1/24              0          0          0          0         0           0
Gi2/1               0          0          0          0         0           0
Gi2/2               0          3          0          9         0           0
Gi2/3               0          0          0          0         0           0
Gi2/4               0          0          0          0         0           0
Gi2/5               0        146          0        333         0           0
Gi2/6               0         29          0         93         0           0
Gi2/7               0          0          0          0         0           0
Gi2/8               0          0          0          0         0           0
Gi2/9               0      13928          0      30573         0           0
Gi2/10              0          0          0          0         0           0
Te2/11              0          0          0          0         0           0
Gi3/1               0          0          0          0         0           0
Gi3/2               0        233          0        591         0           0
Gi3/3               0          0          0          0         0           0
Gi3/4               0          0          0          0         0           0
Gi3/5               0          0          0          0         0           0
Gi3/6               0          0          0          0         0           0
Gi3/7               0          0          0          0         0           0
Gi3/8               0          0          0          0         0           0
Gi3/9               0          0          0          0         0           0
 --More--
Gi3/10              0          0          0          0         0           0
Te3/11              0          0          0          0         0           0
Gi5/1               0          0          0          0         0           0
Gi5/2               0          0          0          0         0           0
Port      Single-Col Multi-Col  Late-Col Excess-Col Carri-Sen     Runts    Giants
Gi1/1              0         0         0          0         0         0         0
Gi1/2              0         0         0          0         0         0         0
Gi1/3              0         0         0          0         0         0         0
Gi1/4              0         0         0          0         0         0         0
Gi1/5              0         0         0          0         0         0         0
Gi1/6              0         0         0          0         0         0         0
Gi1/7              0         0         0          0         0         0         0
Gi1/8              0         0         0          0         0         0         0
 --More--
Gi1/9              0         0         0          0         0         1         0
Gi1/10             0         0         0          0         0         0         0
Gi1/11             0         0         0          0         0         0         0
Gi1/12             0         0         0          0         0         0         0
Gi1/13             0         0         0          0         0         0         0
Gi1/14             0         0         0          0         0         0         0
Gi1/15             0         0         0          0         0         0         0
Gi1/16             0         0         0          0         0         0         0
Gi1/17             0         0         0          0         0         0         0
Gi1/18             0         0         0          0         0         0         0
Gi1/19             0         0         0          0         0         0         0
 --More--
Gi1/20             0         0         0          0         0         0         0
Gi1/21             0         0         0          0         0         0         0
Gi1/22             0         0         0          0         0         0         0
Gi1/23             0         0         0          0         0         0         0
Gi1/24             0         0         0          0         0         0         0
Gi2/1              0         0         0          0         0         0         0
Gi2/2              0         0         0          0         0         0         0
Gi2/3              0         0         0          0         0         0         0
Gi2/4              0         0         0          0         0         0         0
Gi2/5              0         0         0          0         0         0         0
Gi2/6              0         0         0          0         0         0         0
 --More--
Gi2/7              0         0         0          0         0         0         0
Gi2/8              0         0         0          0         0         0         0
Gi2/9              0         0         0          0         0         0         0
Gi2/10             0         0         0          0         0         0         0
Te2/11             0         0         0          0         0         0         0
Gi3/1              0         0         0          0         0         0         0
Gi3/2              0         0         0          0         0         0         0
Gi3/3              0         0         0          0         0         0         0
Gi3/4              0         0         0          0         0         0         0
Gi3/5              0         0         0          0         0         0         0
Gi3/6              0         0         0          0         0         0         0
 --More--
Gi3/7              0         0         0          0         0         0         0
Gi3/8              0         0         0          0         0         0         0
Gi3/9              0         0         0          0         0         0         0
Gi3/10             0         0         0          0         0         0         0
Te3/11             0         0         0          0         0         0         0
Gi5/1              0         0         0          0         0         0         0
Gi5/2              0         0         0          0         0         0         0
Port       SQETest-Err Deferred-Tx IntMacTx-Err IntMacRx-Err Symbol-Err
Gi1/1                0           0            0            0          0
Gi1/2                0           0            0            0          0
Gi1/3                0           0            0            0          0
Gi1/4                0           0            0            0          0
Gi1/5                0           0            0            0          0
Gi1/6                0           0            0            0          0
 --More--
Gi1/7                0           0            0            0          0
Gi1/8                0           0            0            0          0
Gi1/9                0           0            0            0          2
Gi1/10               0           0            0            0          0
Gi1/11               0           0            0            0          0
Gi1/12               0           0            0            0          0
Gi1/13               0           0            0            0          0
Gi1/14               0           0            0            0          0
Gi1/15               0           0            0            0          0
Gi1/16               0           0            0            0          0
Gi1/17               0           0            0            0          0
Gi1/18               0           0            0            0          0
Gi1/19               0           0            0            0          0
Gi1/20               0           0            0            0          0
Gi1/21               0           0            0            0          0
Gi1/22               0           0            0            0          0
Gi1/23               0           0            0            0          0
Gi1/24               0           0            0            0          0
Gi2/1                0           0            0            0          0
Gi2/2                0           0            0            0          0
Gi2/3                0           0            0            0          0
Gi2/4                0           0            0            0          0
Gi2/5                0           0            0            0          0
 --More--
Gi2/6                0           0            0            0          0
Gi2/7                0           0            0            0          0
Gi2/8                0           0            0            0          0
Gi2/9                0           0            0            0          0
Gi2/10               0           0            0            0          0
Te2/11               0           0            0            0          0
Gi3/1                0           0            0            0          0
Gi3/2                0           0            0            0          0
Gi3/3                0           0            0            0          0
Gi3/4                0           0            0            0          0
Gi3/5                0           0            0            0          0
Gi3/6                0           0            0            0          0
Gi3/7                0           0            0            0          0
Gi3/8                0           0            0            0          0
Gi3/9                0           0            0            0          0
Gi3/10               0           0            0            0          0
Te3/11               0           0            0            0          0
Gi5/1                0           0            0            0          0
Gi5/2                0           0            0            0          0
-R1#
-R1#
Port            InOctets   InUcastPkts   InMcastPkts   InBcastPkts
Gi1/1     1113637785034807 3743350496074            98        280384
Gi1/2     913996705379890 3137517225472           101        280603
Gi1/3     569338638572543 1966644007404            37        189648
Gi1/4     468727859419662 1657687361705            35        195201
Gi1/5                  0             0             0             0
Gi1/6      6601748668306   66489052066       2381909       8937648
Gi1/7     74383386086728  739434610773    1396525558      75480325
Gi1/8     74431672412106  750247337444    1343024295      67244084
Gi1/9     78340055819154  781578184682    6428003948      73032610
Gi1/10    48041611103246  478208990490    1551736549     112136879
Gi1/11                 0             0             0             0
Gi1/12        1738527435        142160       5984070           529
Gi1/13           1280455             0          1643          8114
Gi1/14                 0             0             0             0
Gi1/15    27283068799464   79128994464           824         23335
Gi1/16            525018             6            11          8182
Gi1/17                 0             0             0             0
Gi1/18                 0             0             0             0
Gi1/19                 0             0             0             0
Gi1/20                 0             0             0             0
Gi1/21                 0             0             0             0
 --More--         Gi1/22                 0             0             0             0
 --More--         Gi1/23                 0             0             0             0
 --More--
Gi1/24            368203          3970           279           363
Gi2/1       636124545827    2462249739     262198329       5393822
Gi2/2     34752246178093  336704974582   10845386782      44569123
Gi2/3       209661340187     849044943       1207673           806
Gi2/4       384241605937    1926562399         72414       5635337
Gi2/5     243473366166369 2393230901324   16481776055    1502970283
Gi2/6     126863584957878 1217510608581    8704777207      73517942
Gi2/7     68614205682471  666621756225   10862767450    4091825779
Gi2/8     133617728155506 1319194264841    6218379890     102853693
Gi2/9     46452274296448  456267204667    2136698524     415018367
Gi2/10    106956614327213 1052361367753    3990663102      62898683
Te2/11     6132389367124   47734832867    1234196298         60376
Gi3/1     29499007171389  273011279963    8293839436      39346601
Gi3/2     109470657442463 1103831628368    1585022355     120630429
Gi3/3     18962598644556  169920971849    8071424580      52552283
Gi3/4      2289219890798   20692186046     896472418     169873336
Gi3/5                 82             0             0             1
Gi3/6                 82             0             0             1
Gi3/7                 82             0             0             1
Gi3/8                 82             0             0             1
Gi3/9                 82             0             0             1
Gi3/10                82             0             0             1
Te3/11               356             2             1             2
 --More--
Gi5/1                556             3             1             3
Gi5/2                146             0             0             2
Port           OutOctets  OutUcastPkts  OutMcastPkts  OutBcastPkts
Gi1/1     436656605397165 4258841517506    1050603733         37320
Gi1/2     383472238844092 3736972103627    1049901641         37200
Gi1/3     214786706212933 2113335748346     117116913         10973
Gi1/4     177071447245349 1729823308157     117078719         11027
Gi1/5                  0             0             0             0
Gi1/6     14742287836531   69511127580    1039966456       1348626
Gi1/7     206414256393644  684897559896    9162905645      32215614
Gi1/8     188321860080999  683240591493   10048243380      20949201
Gi1/9     197926049314372  701341560526    9269982942      69781396
Gi1/10    128942358993500  454704257331    7927279331      20082527
Gi1/11                 0             0             0             0
Gi1/12     4344711933320    7287937429       5983913           245
Gi1/13     2535316781470   13900201123       2125287           599
Gi1/14                 0             0             0             0
Gi1/15    11048557170608  103426009895     125715686         46314
Gi1/16        6992803218          8215      68172486         34824
Gi1/17                 0             0             0             0
Gi1/18                 0             0             0             0
Gi1/19                 0             0             0             0
 --More--
Gi1/20                 0             0             0             0
Gi1/21                 0             0             0             0
Gi1/22                 0             0             0             0
Gi1/23                 0             0             0             0
Gi1/24            426917          3366           170             9
Gi2/1       274497196939    2323842540     259386662         17276
Gi2/2     93232337057333  327235664035   10680429016      10373588
Gi2/3       653998045302     921468589       1208153           900
Gi2/4       198503911706    1855625309      75443908         22519
Gi2/5     604617011409061 2086510628016   14125424006      21252239
Gi2/6     336466777386383 1086323467971   11970943839      34735759
Gi2/7     168224561540946  565985837791    8369272700      75754027
Gi2/8     341544568640363 1111167574248    6026578591      15698093
Gi2/9     122991702765231  418249734567    7948344244       5135063
Gi2/10    265614241187073  940316064735    5028777892       6766823
Te2/11      742979090129    6000189877    1240446060       6732322
Gi3/1     87929261231384  299911157415   10271598248       3714341
Gi3/2     264019502095414  876507805207    5313332566       8478725
Gi3/3     55017629771923  175460216110    6628100408      16213799
Gi3/4      6751064956757   21499810552     889207218       2915094
Gi3/5                 82             0             0             1
Gi3/6                 82             0             0             1
Gi3/7                 82             0             0             1
 --More--
Gi3/8                 82             0             0             1
Gi3/9                 82             0             0             1
Gi3/10                82             0             0             1
Te3/11               356             2             1             2
Gi5/1                556             3             1             3
Gi5/2                146             0             0             2
As I was unable to conclude source of broadcast so I started NETDR.
R1#sh netdr captured-packets p
A total of 4096 packets have been captured
The capture buffer wrapped 0 times
Total capture capacity: 4096 packets
------- dump of incoming inband packet -------
interface Gi3/4.1300, routine process_rx_packet_inline, timestamp 23:41:38.909
dbus info: src_vlan 0x732(1842), src_indx 0x83(131), len 0x40(64)
  bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x4732(18226)
  47020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.C4.C3.AD, protocol 0806
layer 3 data: 00010800 06040001 000FBBC4 C3ADAC1D CBE10000 00000000
              AC13B61E 00000000 00000000 00000000 00000000 00000000
              00000000 00000000 00000732
  4F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--
-R1#sh netdr captured-packets ?
  |  Output modifiers
  <cr>
 --More--         interface Gi3/4.1299, routine process_rx_packet_inline, timestamp 23:41:38.909
dbus info: src_vlan 0x731(1841), src_indx 0x83(131), len 0x40(64)
  bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x4731(18225)
  57020400 07310000 00830000 40000000 E0000570 03000040 00000008 47310000
destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.BC.24.CD, protocol 0806
layer 3 data: 00010800 06040001 000FBBBC 24CDAC13 A6020000 00000000
              AC13A61E 00000000 00000000 00000000 00000000 00000000
  67020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.BB.34.ED, protocol 0806
layer 3 data: 00010800 06040001 000FBBBB 34EDAC1D CBA10000 00000000
              00000000 00000000 00000731
 --More--           6F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  77020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
layer 3 data: 00010800 06040001 000FBBBC 24CDAC1D CB990000 00000000
  7F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--                       AC13B61E 00000000 00000000 00000000 00000000 00000000
  87020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.8A.08.E6, protocol 0806
layer 3 data: 00010800 06040001 000FBB8A 08E6AC13 B6010000 00000000
  8F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         ------- dump of incoming inband packet -------
  97020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  9F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--           bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x4732(18226)
  A7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  AF020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  B7020400 07310000 00830000 40000000 E0000570 03000040 00000008 47310000
 --More--         layer 3 data: 00010800 06040001 000FBBBB 34EDAC13 A6030000 00000000
  BF020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  C7020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
 --More--
  D7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  DF020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         dbus info: src_vlan 0x732(1842), src_indx 0x83(131), len 0x40(64)
  E7020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  EF020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  F7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.BC.24.CD, protocol 0806
  FF020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  0F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--                       00000000 00000000 00000732
  17020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  1F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         interface Gi3/4.1300, routine process_rx_packet_inline, timestamp 23:41:38.909
  27020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  37020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--           3F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  57020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
interface Gi3/4.1300, routine process_rx_packet_inline, timestamp 23:41:38.913
  5F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  6F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  87020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  8F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
 --More--         layer 3 data: 00010800 06040001 000FBB8A 08E6AC13 B6010000 00000000
              012C0000 03E8AC22 00000732
 --More--
              012C0000 03E8AC13 00000732
  B7020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
              012C0000 03E8AC1D 00000732
  C7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         destmac FF.FF.FF.FF.FF.FF, srcmac 00.0F.BB.C4.C3.AD, protocol 0806
  E7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         interface Gi3/4.1300, routine process_rx_packet_inline, timestamp 23:41:38.913
interface Vl505, routine process_rx_packet_inline, timestamp 23:41:38.913
dbus info: src_vlan 0x1F9(505), src_indx 0x1(1), len 0x52(82)
  bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x380(896)
 --More--           15020400 01F90000 00010000 52080000 00840428 0E000043 00000000 03800000
destmac 00.00.0C.9F.F0.0F, srcmac 00.40.43.82.75.E6, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x88, totlen 64, identifier 47989
  df 0, mf 0, fo 0, ttl 63, src 172.29.128.206, dst 172.19.164.107, proto 132
  1F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  2F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
 --More--           4F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  67020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
  7F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
 --More--         layer 3 data: 00010800 06040001 000FBBBB 34EDAC1D CBA10000 00000000
  B7020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--
interface Gi3/4.1300, routine process_rx_packet_inline, timestamp 23:41:38.917
  CF020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
  D7020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
interface Gi3/4.1299, routine process_rx_packet_inline, timestamp 23:41:38.917
  0F020400 07310000 00830000 40000000 E0000570 03000040 00000008 47310000
  17020400 07310000 00830000 40000000 E0000570 03000040 00000008 47310000
 --More--         interface Gi3/4.1299, routine process_rx_packet_inline, timestamp 23:41:38.917
  27020400 07310000 00830000 40000000 E0000570 03000040 00000008 47310000
layer 3 data: 00010800 06040001 000FBBC4 C3ADAC13 A6040000 00000000
  2F020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--           37020400 07320000 00830000 40000000 E0000570 03000040 00000008 47320000
 --More--         layer 3 data: 00010800 06040001 000FBBC4 C3ADAC1D CBE10000 00000000
  9F020400 07320000 00830000 40000000 E0000520 03000040 00000008 47320000
 --More--
-R1#sh netdr captured-packets | i interface|flood
R1#debug netdr clear-capture
Clearly, we were getting high ARP requests from int Gi3/4.1300 and after shutting this VLAN sub-interface, things got normalised.
On further investigation on this LAN segment, we found STP misconfiguration which was causing L2 loop resulting in high ARP requests on our router which was causing High CPU utilisation.
These kind of issues has become day to day issue in our network as we are having multiple VLAN segments connected to our Cisco 7606 Router and one misconfiguration in any of thousands connected node is causing high broadcasts leading to high CPU and unstability of our core 7606 router.
I have few doubts/questions:
1.) Is there any cinfiguration we can do in router in order to avoid increase in ARP Process, or, block ARP requests after particular number of repeated requests ??
2.) Such high number of ARP requests are normal in these kind of scenarios, or we are doing something wrong??
3.) Any other way to know the source of VLAN which is creating broadcast instead of NETDR ??
4.) Any configuration which can alert us about high ARP requests or, broadcast from some particular VLAN, so that we can block that VLAN proactively??
5.) Any other method to analyse things faster so that we can take action quickly with just few commands ??
6.) Any more things that I should log during high CPU to get more clear picture of problem. ??
7.) Is NETDR safe to use when CPU utilidation is almost 100% ??
12 Replies 12
Seb Rupik
Hi there,
If you have L2 loops on your network why not configure BPDU guard on your access layer?...I assume it is users causing the loops?!
You could also try configuring DAI :
http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/dynarp.html
...in particular look at rate-limiting APR packets:
http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/dynarp.html#pgfId-1039658
Between these two techniques you should be able to mitigate this issue.
cheers,
Seb.
First of All, Thanks for your reply.
We have M/W transmission Nodes connected to this router which run their own RSTP, so BPDU do come to our router, I don't think we can use BPDU Guard in this situation, or do I ?
This feature look good, but I have few doubts:
Can I use this ARP rate limit on sub-interfaces ?
If I do use ARP rate-limit on sub-interface, then in case rate of incoming ARP packets exceeds the configured limit, the router will place the sub-interface/VLAN interface to err-disabled mode or, will place whole interface in err-disabled mode.??
I think if I can configure this rate limit on sub-interface level then it will pretty much solve my issue as it will put particular sub-interface on err-disabled mode, and we will also get to know the source VLAN for our further diagnosis.
You should expect BPDUs on trunk interfaces to other switches so don't enable BPDU guard here. Do make sure your router has the lowest root ID.
You'll want BPDU guard on access switchports which are connected to user devices.
Regarding rate-limiting, ARP inspection is enabled per VLAN, so if you have a trunk interface carrying a VLAN with ARP traffic exceeding your confgidured limit, I assume it will err-diable the entire interface....not sure...try it in a lab :)
I tried to enable ARP rate-limit on VLAN subinterface in router, but router not letting me configure the same, while I am able to configure same at interface level. So, I assume ARP rate-limit can be configured on interfaces only not on subinterfaces and so it will err-disable entire interface instead of subinterface in case of ARP request exceeding limit set by rate-limiter.
We have multiple subinterfaces(~50) configured within each interface so, err-disabling whole interface will stop traffic from all those VLANs also when issue be with particular VLAN only, so I think its not good idea for us to enable ARP rate-limiter.
Also, I was curious if I enable DAI, is it possible to just send trap or, log it, if particular interface or, vlan receives high ARP requests instead of shutting it down, this can actually lead us to source of VLAN causing issue and we can take action appropriately.
DAI will only log packets or send traps when it drops packets, which it will only do with rate-limiting enabled! :)
Are you able to configure DAI on your access layer where you have only one VLAN per switchport?
Not possible to enable DAI on access layer. We are using Ethernet-Over-SDH point to mulit-point for access and NE involved don't have DAI facility.
Hi Nishant,
   Did you resolve this issue.If yes,I would like know how you resolved it.
Prajith
Hi Prajith,
Problem still not resolved. Meanwhile, I am just trying to just enable DAI per VLAN so that I can get source VLAN of high ARP requests during ARP floods and take appropriate action to block particular VLAN.
Any more suggestions will be appreciated.
Nishant
Hi Nishant,
  Have you checked the system for virus and malware attack.
Prajith
End Nodes are Telecom equipments, no virus or, malware attack possible.
Also, is there any command to know number of ARP requests coming on any interface ??
You need DAI enabled for this one:
show ip arp inspection interfaces [ interface_id ]
