11-23-2010 11:53 PM - edited 03-04-2019 10:34 AM
Dear all,
Today Morning i got this log:
%MLS_ACL_COMMON-DFC10-4-MLS_ACL_CONSIST: ACL TCAM inconsistency seen at index 29764
from Cisco 6513 Cat Switch.
Can anyone tell me what is this log?
11-24-2010 05:09 AM
Hello Ahmed,
I have taken below output from cisco tool..may be useful to you.
1. %MLS_ACL_COMMON-4-MLS_ACL_CONSIST: ACL TCAM inconsistency seen at index [dec]
The ACL TCAM inconsistency checker found an inconsistency between software and hardware TCAM entries and has fixed it. [dec] is the index where the inconsistency was found.
You can post your IOS name and search for any bug as a precaution
Mahesh
11-24-2010 05:16 AM
IOS (tm) s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF8
11-24-2010 05:30 AM
Hello Yacoob,
Look for bug in mentioned IOS and i did not find any bug related to TCAM.
As a suggestion that is just a warning message and it is already fixed. If this happen again and again
you can consult cisco tac else you can ignore...my view
Mahesh
11-24-2010 05:32 AM
Thanks so much
