NAT on a WS-C3560-24TS Switch ( 12.2(25)SEE3)
winston123
Hello all,
I need to configure NAT  (ip nat inside source static 172.x.x.x. 202.x.x.x route-map voicegateway), but can't seem to find the right command.
I find the command: sh ip nat translations, but can't find the command to configure, not in the global configuration or any other sub-level either
Do i have to enable something first, before I am able to conf NAT..
HELP!.
vragotha
Level 3
Level 3
NAT is not supported on this platform
Thanks a lot Vijay
Talha Ansari
NAT is possible on switches that have layer 4 capability like 6500... on 3560 it is not possible.
check this
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Ah i see,
Thanks a lot for your help and info
