6k - SSO - SUP720 Question
panayiotiscy
Level 4
Level 4
Hello netpros,
Is it possible to combine 1xSUP-7203B with 1xSUP-7203BXL in a single 6k chassis in order to achieve SSO redundancy?
Ashish
Hi Panayiotiscy,
It should come up in SSO, however the system would run in lowest common denominator mode i.e. PFC 3B.
Hello Ashish and thanks for asnwering.
So i understand that the system will be limited to the hw capabilities of the SUP-7203B
is this correct?
That's correct. You can check operating pfc mode using command 'show platform hardware pfc mode PFC3B.
