Dinamic routic EIGRP
My network working with static routes but I can change for dinamic routing, (EIGRP)
Firts Site
Router eigrp 1
network 192.168.0.0
no auto-summary
eigrp stub connect
redistributed static
Second Side
Router eigrp 1
network 192.168.0.0
no auto-summary
eigrp stub connect
But not work EIGRP. Addicional have statics routes and de others sites connect to First Site with static routes
Help me please
2 Accepted Solutions
Mark Malone
Hey is there a reason your using stub you should remove it until you have the neighbour relationship fully formed and advertising routes.
what is the current status of the eigrp neighbours ?
Ganesh Hariharan
Hello ,
Normally stub configuration are done at bracnh level end so that query packets are flooded in case of any breakage in network.
Agree with Mark, you can remove stub confgiration and show the eigrp neighbourship status.
-GI
Mark Malone
Ganesh Hariharan
Hello ,
-GI
