6to4 tunneling issues
rpo83rpo83
have the following setup:
PC---fa0/0-Router1-fa0/1---fa0/0-Router2-fa0/1---PC
and am trying to get 6to4 tunnels happening between the two routers but
to no avail. I believe its something in the route in place but for the
life of me I cant spot the error, as the error I get when I try to ping
from a PC to the non-directly attached router I get "request timed out"
errors
It might be a tunnel problem as the destination comes up as "UNKNOWN"
Can someone please help!!! Ive got GRE tunneling and manual tunnels
working, but need to test this config (6to4 tunnels) as well.
Configs as follows:
Router1#sh run
version 12.3
hostname Router1
boot-start-marker
boot-end-marker
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ipv6 unicast-routing
interface Tunnel0
no ip address
no ip redirects
ipv6 address 2002:C0A8:6301::1/64
tunnel source FastEthernet0/1
tunnel mode ipv6ip 6to4
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address 2002:C0A8:6301:1::1/64
ipv6 enable
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 192.168.99.1 255.255.255.0
duplex auto
speed auto
ipv6 enable
interface Serial0/1
no ip address
shutdown
ip http server
no ip http secure-server
ip classless
ipv6 route 2002::/16 Tunnel0
line con 0
line aux 0
line vty 0 4
end
Router2#sh run
version 12.3
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Tunnel0
no ip address
no ip redirects
ipv6 address 2002:C0A8:2101::1/64
tunnel source FastEthernet0/0
ip address 192.168.33.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface BRI0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
ipv6 address 2002:C0A8:2101:1::1/64
ipv6 enable
interface Serial0/1
no ip address
shutdown
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
Configs attached include the sh route and sh int tunnel 0 commands as well as the router configs
Harold Ritter
The issue is that fa0/1 on router1 and fa0/0 on router2 are not on the same ipv4 subnet. Bear in mind that ipv4 connectivity must be established for ipv6 traffic to be transported in an ipv4 tunnel.
Since the two routers are back to back, change the ip address on fa0/0 of router2 to 192.168.99.2 and the ipv6 address of tu0 to ipv6 address 2002:C0A8:6302::1/64.
You will also need to change the ipv6 address of fa0/1 to 2002:C0A8:6302:1::1/64 on router2 and the connected PC.
Hope this helps,
