QoS assistance
aoshea
Dear Netpro,
Wondering if someone could point me in the right direction of some material to assist me with my QoS configuration.
We have implemented a VoIP solution across our 5 remote sites and now need to configure our routers to support QoS.
Each site has a 2 Mbps link that carries two vlans, I have already rate-limited the configuration to groom traffic before it goes across the link, but wondering if someone could help me grow this configuration to support VoIP traffic marked with DSCP value of 40.
Here is a extract from one of the site configs.
interface FastEthernet0/0.880
description *** CONNECTION BETWEEN ***
bandwidth 2000
encapsulation dot1Q 880
ip address 172.16.31.10 255.255.255.252
no ip redirects
ip accounting access-violations
ip bandwidth-percent eigrp 100 90
rate-limit output 2000000 2000000 2000000 conform-action transmit exceed-action drop
interface FastEthernet0/0.881
description *** ***
bandwidth 1999
encapsulation dot1Q 881
ip address 172.16.32.10 255.255.255.252
no ip redirects
end
Thanks in advance.
Regards, Adrian.
Chris Deren
Have you read the Cisco QoS SRND document at www.cisco.com/go/srnd it is pretty good.
What is your topology, what kind of access do you have to the remote sites?
If you want to limit traffic with DSCP of 40, you can use policy-map with policer, for example:
policy-map VoIP
class VVLAN-VOICE
set ip dscp 46 ! DSCP EF (Voice)
police 128000 8000 exceed-action drop
Chris
