7120 router stuck in ROMON mode
rangap26.
My 7120 router stuck in romon mode.
When i give reset
It gives the following error
*** TLB (Load/Fetch) Exception ***
Access address = 0x0
PC = 0x0, Cause = 0x8, Status Reg = 0x3040d003
ROM Monitor Can Not Recover From Exception
A Board Reset Is Issued
it keeps on going
after i give crtl + break only it return to romon mode
after that if give boot flash
after decompressing it gives
No fault history 0x0. Need 11.1 (2) or higher ROM
Free space check for bootflash:crashinfo_20060729-012548 failed (-1/9279)
and
Nested r4k_return_to_monitor call (2 times)
and return back to romon
Can any one help me regarding this
plase
Ranga
rangap26.
Hi ,
when i swicth off the power and power on
it says the same thing
Ranga
