7200 - G1 PortChan MTU‏
johnelliot6
Level 2
Level 2
Have a G1, with one active Gig port in a portchan (Second member is currently disconnected, but is also a Gig port on the G1) - No other ports are configured as member ports.
Gi0/1 (Active member) has an mtu of 1998(As does innactive member port) - Portchan doesnt have an mtu configured (So is defaulting to 1500)
Attempting to change the mtu on the portchan, I get the following:
(config)#interface Port-channel1
(config-if)#mtu 1998
% At least one member of the channel group 1 is not a 2FE port adapter
Any suggestions why this is happening?
#sh int gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
Hardware is BCM1250 Internal MAC, address is 00d0.bc5b.bc1b (bia 00d0.bc5b.bc1b)
Description: GEC_TO_CSW01_24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 6/255, rxload 5/255
#sh int gigabitEthernet 0/3
GigabitEthernet0/3 is down, line protocol is down
Hardware is BCM1250 Internal MAC, address is 00d0.bc5b.bc1b (bia 00d0.bc5b.bc19)
Description: GEC_TO_CSW02_24
reliability 254/255, txload 1/255, rxload 1/255
#sh int port-channel 1
Port-channel1 is up, line protocol is up
Hardware is GEChannel, address is 00d0.bc5b.bc1b (bia 00d0.bc5b.bc1b)
reliability 255/255, txload 10/255, rxload 5/255
Phys-int conf:
interface GigabitEthernet0/1
description GEC_TO_CSW01_24
mtu 1998
no ip address
ip mtu 1998
ip flow ingress
duplex auto
speed auto
media-type rj45
no negotiation auto
channel-group 1
end
And portchan1:
no ip address
ip access-group 103 in
ip flow ingress
load-interval 30
duplex full
end
Reza Sharifi
Since gi0/3 is down, can you delete it from portchannel 1 and then try setting the mtu on the portchannel?
interface GigabitEthernet0/3
no channel-group 1
Also, are gi0/1 and 0/3 in the same port adapter?
Just an update to this - Replicated the setup on a spare 7200 w/ G1:
(gi0/1 + gi0/3 are on same NPE-G1)
Removing Gi0/3 from channel group made no difference.
Changing mtu on physical Interfaces had no effect (i.e. It remained in the Interface config as "mtu 1998") - I was able to change the mtu on the physical Ints by first issuing:
ip mtu some_other_number_besides_1500 - Once this was done, I was able to set the mtu on the physical Ints to 1500.
But, I was then still unable to change the mtu on the portchan - Still received "
% At least one member of the channel group 1 is not a 2FE port adapter" no matter what value I entered.
So, as a last resort I defaulted the physical Int, then was able to change the mtu on the portchan without it complaining, and then re-added the phyical Int back to the portchan, and I now have 1998 mtu.
(config)#default interface gigabitEthernet 0/3
Building configuration...
GigabitEthernet0/3 taken out of port-channel1
The "[no] negotiation auto" command will have no effect with this interface
GigabitEthernet0/3: Setting default media-type to RJ45
Interface GigabitEthernet0/3 set to default configuration
(config)#interface port-channel 1
7200(config-if)#interface GigabitEthernet0/3
7200(config-if)# description GEC_TO_CSW02_24
7200(config-if)# channel-group 1
%Interface MTU set to channel-group MTU 1998.
GigabitEthernet0/3 added as member-1 to port-channel1
7200#sh interfaces port-channel 1
  Hardware is GEChannel, address is 0003.e416.7819 (bia 0003.e416.781b)
  MTU 1998 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, Unknown Speed, media type is unknown media type
  output flow-control is unsupported, input flow-control is unsupported
    No. of active members in this channel: 1
        Member 0 : GigabitEthernet0/3 , Full-duplex, 1000Mb/s
7200#sh interfaces gigabitEthernet 0/3
GigabitEthernet0/3 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is 0003.e416.7819 (bia 0003.e416.7819)
