7206vxr IOS 15.2
craig bache
Hi All
I am having an issue with a 7206vxr (NPE-G2) this is running 2gig Dram and 1 Gig flash. The issue is when loading the new 15.2 code it seems to give an error %SYS-3-IMAGE_TOO_BIG but there is more than enough room on the flash. The strange thing is this does not load with the commands below but if I remove the boot statements it will load but still gives me the error %SYS-3-IMAGE_TOO_BIG.
booting from the boot image.
boot-start-marker
boot  system flash disk2:c7200p-advipservicesk9-mz.152-4.M2.bin
boot  system flash bootflash:c7200p-kboot-mz.124-4.XD5.bin
boot-end-marker
Router#reload
Proceed  with reload? [confirm]
*Apr   2 18:13:48.211: %SYS-5-RELOAD: Reload requested by console. Reload Reason:  Reload Command.
System  Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Technical  Support: http://www.cisco.com/techsupport
Copyright  (c) 2006 by cisco Systems, Inc.
Socket  jumper: not present Failsafe jumper: present = normal
FPGA  revision 0x00000026
C7200  platform with 2095104 Kbytes of main memory
Readonly  ROMMON initialized
Self  decompressing the image :  #################################################################################################################################  [OK]
%SYS-4-CONFIG_NEWER:  Configuration from version 15.2 may not be correctly  understood
%SYS-3-IMAGE_TOO_BIG:  'disk2:c7200p-advipservicesk9-mz.152-4.M2.bin' is too large for available memory  (46143512 bytes).
%SYS-6-READ_BOOTFILE_FAIL:  disk2:c7200p-advipservicesk9-mz.152-4.M2.bin File read failed -- Not enough  space.
%SYS-6-BOOT_MESSAGES:  Messages above this line are from the boot loader.
               Restricted Rights Legend
Use,  duplication, or disclosure by the Government is
subject  to restrictions as set forth in subparagraph
(c)  of the Commercial Computer Software - Restricted
Rights  clause at FAR sec. 52.227-19 and subparagraph
(c)  (1) (ii) of the Rights in Technical Data and Compute
Software  clause at DFARS sec. 252.227-7013.
            cisco Systems, Inc.
            170 West Tasman Drive
            San Jose, California 95134-1706
Cisco  IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE  SOFTWARE (fc1)
Copyright  (c) 1986-2006 by Cisco Systems, Inc.
Compiled  Tue 19-Dec-06 16:07 by alnguyen
Image  text-base: 0x0000A368, data-base: 0x00C7400
Any help much appreciated.
Craig
Edison Ortiz
Try upgrading your bootloader, you are running a very old 12.4(4)XD5 image.
Sounds like a match to:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsh41497
Edison Ortiz
Thank you for the responses, will let you know how I get on....
Regards Craig
cconn
I concurr on bootloader upgrade needed, I had this exact problem and a bootloader upgrade corrected it.
Thanks for the response, changing the bootloader has fixed the issue.
Anyone seen the folowing, (this message seems to be happening now)
Self decompressing the image : ############################################################################################################################## [OK]
*** No sreloc section../VIEW_ROOT/cisco.comp/system-infra/mgmt/logger/syslog/src/syslog.c:3381 Max number of VRF tables cannot be zero!!
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
Regards Craig
