7206vxr NPE-300
stresspattern
What is the maximum media packets the 7206 can handle per second. We are interfacing our 7206vxr NPE-300 with a Nextone SBC (sound Board Controller) and its causing the CPU on the 7206 to run at 98%.
2 Accepted Solutions
mohammedmahmoud
Level 11
Level 11
Hi there,
Kindly check the following link, but bare in mind that when there is ACL, encryption, compression and QoS configuration and not using CEF, dramatically effects the router performance:
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
HTH,
Mohammed Mahmoud.
pciaccio
Level 4
Level 4
The attached document will tell you the specs for the router..Please rate....
mohammedmahmoud
Level 11
Level 11
Hi there,
HTH,
Mohammed Mahmoud.
Thank you for your prompt response.
Marvin Sosa
pciaccio
Level 4
Level 4
Marvin Sosa
