7206VXR NPE-G2 Slower Inbound than Outbound
ikalani12065
We're seeing an anomaly on our inbound network traffic being slower than our outbound traffic; It's about 20-50 times slower and fluctuates dramatically.  Internal traffic is fine and we get full line speed.  We're running two 7206VXR routers with NPE-G2 each running a BGP connection to two different providers each receiving full tables.  To try to isolate the problem we've pulled the advertisement from one upstream and have statically routed any of our traffic to the download source as to avoid the use of BGP.  Removing these complexities the problem still exists.  Any help would be appreciated.  We've tested this from many sources but in the config examples I'm posting the source IP for test file transfers is 74.86.116.210.  This config on either router produces the same results even though they are with different providers. Here are the relevant config segments (counters cleared shortly before grabbing the config):
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(4)XD4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 23-Oct-06 16:54 by kesnyder
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID 33319489
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.9
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 200 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
ip cef
interface GigabitEthernet0/1
 description CONNECTION TO DISTRIBUTION SWITCH
 no ip address
 load-interval 30
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
interface GigabitEthernet0/1.47
 encapsulation dot1Q 47
 ip address XXX.XXX.XXX.XXX 255.255.255.0 secondary
 ip tcp adjust-mss 1436
 standby 50 ip XXX.XXX.XXX.1
 standby 50 priority 160
 standby 50 preempt
interface GigabitEthernet0/2
 description CONNECTION TO INTERNET UPSTREAM
 ip address YYY.YYY.YYY.YYY 255.255.255.252
 load-interval 30
 duplex full
 speed 1000
 media-type sfp
 no negotiation auto
ip route 74.86.116.210 255.255.255.255 YYY.YYY.YYY.ZZZ
scheduler allocate 3000 1000
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0014.1c30.af1b (bia 0014.1c30.af1b)
  Description: CONNECTION TO DISTRIBUTION SWITCH
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 24/255, rxload 131/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:00:06
  Input queue: 0/75/9/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 516542000 bits/sec, 74589 packets/sec
  30 second output rate 96853000 bits/sec, 32405 packets/sec
     532103 packets input, 465207530 bytes, 0 no buffer
     Received 84 broadcasts, 0 runts, 0 giants, 0 throttles
     8 input errors, 0 CRC, 0 frame, 0 overrun, 8 ignored
     0 watchdog, 48 multicast, 0 pause input
     215449 packets output, 71835861 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/2 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0014.1c30.af1a (bia 0014.1c30.af1a)
  Description: CONNECTION TO INTERNET UPSTREAM
  Internet address is YYY.YYY.YYY.YYY/30
     reliability 255/255, txload 66/255, rxload 15/255
  Full-duplex, 1000Mb/s, link type is force-up, media type is LX
  Last clearing of "show interface" counters 00:01:04
  Input queue: 0/75/3/0 (size/max/drops/flushes); Total output drops: 0
  30 second input rate 62427000 bits/sec, 24819 packets/sec
  30 second output rate 260752000 bits/sec, 34769 packets/sec
     1597314 packets input, 492958219 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     4 input errors, 0 CRC, 0 frame, 0 overrun, 4 ignored
     0 watchdog, 0 multicast, 0 pause input
     2232870 packets output, 2080358220 bytes, 0 underruns
CPU utilization for five seconds: 59%/56%; one minute: 58%; five minutes: 56%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  19   2499185401190427476        209  0.98%  0.66%  0.62%   0 ARP Input
  94   374486908  43703755       8568  0.90%  0.86%  0.87%   0 CEF process
  73   912363132  66312960      13758  0.73%  0.58%  0.54%   0 IP Input
 161        7632      4004       1906  0.24%  0.04%  0.13%   2 SSH Process
  41    20239804   5797234       3491  0.16%  0.06%  0.06%   0 Net Background
 223    23211012 391925247         59  0.08%  0.07%  0.08%   0 HSRP IPv4
  16    14268656 510330634         27  0.08%  0.01%  0.01%   0 EnvMon
 238   482988140 183714632       2629  0.08%  0.08%  0.08%   0 BGP Router
 226     2025136 873403021          2  0.08%  0.06%  0.08%   0 PPP manager
  45    15934272  28739265        554  0.08%  0.09%  0.08%   0 Per-Second Jobs
  10        5388    478128         11  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  11           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
   8           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  15           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  12       43024  28607535          1  0.00%  0.00%  0.00%   0 IPC Periodic Tim
Leo Laohoo
Well, the output to the command "sh interface G0/2 is totally useless.
However, in 64 seconds you're getting input errors already?  That's not good.   And look at Gi0/1, within 6 seconds after you've cleared the counters you've got input errors.
I'm suspecting this is speed/duplex mismatch error you're seeing.
