7206VXRG1/2+VPNk9 problem with PA-MC-8TE1+:
Maleksalim
HI all,
I have a problem with my router 7206VXRG1/2+VPNk9, when i add 3 card of PA-MC-8TE1+: in the right side it's ok but when i add the fourth one in the left the router doesn't recognise it.
Any Idea?
Nagaraja Thanthry
Can you please post the output of "show diag" after putting the card into the router?
NT
Hi salim,
In 7206 we have concept of bandwidth point. here it is important to know what you have inserted in left part of router.
Please issue sh ver command and search for below output
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 740 bandwidth points.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 200 bandwidth points
here you can see supported capacity is 600 bw point. So if you have already inserted cards with total of 600 bw points then it will not supporty
any more.
please have a sh ver and verify this check point.
please have a look at below doc. for more detail
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_presentation09186a008009184d.pdf
Mahesh
