7513 crash - urgent help!
carl.arce
We had a crash and restart on the 7513. After the router was restarted, some static routes were dissapear so we had to use a backup config to get that routes again. I see in the logging probably a PS is failing, but there are lot of more messages.
Any help will be wellcomed !!
Santosh Shetty
Did you confirmed configuration was saved after adding routes? How many routes you had in config, I can see only 2 default route in running config.
