Showing results forĀ
Search instead forĀ
Did you mean:Ā
7600-SIP-200 Issue
karim7784
We have a cisco 7600 router that have a 7600-SIP-200 module installed on it slot 3 when we try to test the router we have the module give the ollowin error:
% module 3 is operationally off (Module  Failed SCP dnld)
Knowing that we have another router the same model exactly and the IOS and Bootstrap image and is wirking fine here is the show version and show module :
Router#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SRA6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Oct-07 19:13 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Router uptime is 25 minutes
Uptime for this control processor is 25 minutes
Time since Router switched to active is 24 minutes
System returned to ROM by  power cycle (SP by power on)
System image file is "bootdisk:s72033-ipservicesk9_wan-mz.122-33.SRA6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609-S (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID FOX1147H0WS
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Router#show module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1152BGVW
  3    0  4-subslot SPA Interface Processor-200  7600-SIP-200       JAE12034Q8V
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       JAF1150ABAA
  6    2  Supervisor Engine 720 (Warm)           WS-SUP720-3B       JAF1150ABFJ
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001e.7ae2.817c to 001e.7ae2.8193   3.1   12.2(18r)S1  12.2(33)SRA6 Ok
  3  001e.7a5c.3d00 to 001e.7a5c.3d3f   2.303 Unknown      Unknown      PwrDown
  5  001b.d50d.a420 to 001b.d50d.a423   5.6   8.5(2)       12.2(33)SRA6 Ok
  6  001b.d50d.a474 to 001b.d50d.a477   5.6   8.5(2)       12.2(33)SRA6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       JAF1150AMMP  4.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       JAF1149010Z  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          JAF115000MM  3.1    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       JAF115001GW  2.3    Ok
  6  MSFC3 Daughterboard         WS-SUP720          JAF115000P3  3.1    Ok
Mod  Online Diag Status
  1  Pass
  3  Not Applicable
  5  Pass
  6  Pass
I did everything I know :
Check the hardware and software compatibility do reset to the module.
do I have to install any specific package to run this module?
I appreciate your Advice.
It was Hardware Failure I have changed the module and it work fine.
