7603-S DC PSU
mohameddz
Hi;
I have a 7603-s with dual DC power supply when I perform show environment I have on PSU 2 message no DC active; and when I performe show power I got that both PSU are working bellow the show:
#sh environment status
backplane:
operating clock count: 2
fan-tray 1:
fan-tray 1 type: FAN-MOD-3SHS
fan-tray 1 mode: Restricted-power
fan-tray 1 fan-fail: OK
clock 1:
clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: DC active
power-supply 1 incompatible with fan: OK
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: No DC active
power-supply 2 incompatible with fan: OK
power-supply 2 power-output-fail: OK
sh power
system power redundancy mode = combined
system power total = 2448.60 Watts (58.30 Amps @ 42V)
system power used = 1049.16 Watts (24.98 Amps @ 42V)
system power available = 1399.44 Watts (33.32 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-1500-DC 1469.16 34.98 OK OK on
2 PWR-1500-DC 1469.16 34.98 OK OK on
regards.
Hi @mohameddz
 It seems both power suply are ok but power supply 2 is not receving current.
Hi @Flavio Miranda
thak you for your reply
but is PSU 2 is not receving power it should  not show state on in show power; if I unplug the cable or shutdown the power source for the PSU the state change
@mohameddz you are right.
Unless it is receiving but less than it should. But here is just a long shot
 Did you try to remove the power supply and plug it again?
yes already done plug and unplug
