Cisco ASR1000 Unknown SPA Interface Processor after upgrade to 16.9.5
hello , i upgrade our Cisco ASR1006 to 16.3 ,
after upgrading system and hw-model,
the system can't see any interfaces,
the card line(ASR1000-6TGE) is set on slot 2
Router#show platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
2                             unknown               00:21:33
R0        ASR1000-RP2         ok, active            00:21:33
F1        ASR1000-ESP40       ok, active            00:21:33
P0        ASR1006-PWR-AC      ok                    00:20:38
P1        ASR1006-PWR-AC      ps, fail              00:20:37
Slot      CPLD Version        Firmware Version
2         N/A                 N/A
R0        14111801            16.9(5r)
F1        1003190E            15.2(1r)S
Router#sh inventory
NAME: "Chassis", DESCR: "Cisco ASR1006 Chassis"
PID: ASR1006           , VID: V02  , SN: FOX1437H1FG
NAME: "module 2", DESCR: "Cisco ASR1000 Unknown SPA Interface Processor"
PID: ASR1000-SIP-UNKNOWN, VID:      , SN:
NAME: "module R0", DESCR: "Cisco ASR1000 Route Processor 2"
PID: ASR1000-RP2       , VID: V05  , SN: JAE192304EH
NAME: "module F1", DESCR: "Cisco ASR1000 Embedded Services Processor, 40Gbps"
PID: ASR1000-ESP40     , VID: V03  , SN: JAE194006YD
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1006 AC Power Supply"
PID: ASR1006-PWR-AC    , VID: V02  , SN: ART1438Q00A
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1006 AC Power Supply"
PID: ASR1006-PWR-AC    , VID: V02  , SN: ART1432Q013
Router#sh version
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9_NOLI-M), Version 16.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 18:53 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 21 minutes
Uptime for this control processor is 23 minutes
System returned to ROM by Reload Command
System image file is "bootflash:/asr1000rpx86-universalk9_noli.16.09.05.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: EvalRightToUse
License Level: adventerprise
Next reload license Level: adventerprise
Smart Licensing Status: Smart Licensing is DISABLED
cisco ASR1006 (RP2) processor (revision RP2) with 4187925K/6147K bytes of memory.
Processor board ID FOX1437H1FG
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1873919K bytes of eUSB flash at bootflash:.
78085207K bytes of SATA hard disk at harddisk:.
0K bytes of WebUI ODM Files at webui:.
17 Replies 17
Leo Laohoo
Ummmmm How long has this "evaluation" license been on?
What does the logs say?  If the SPA has failed it will show up in the logs.
hello , thanks for the reply,
I think not license issues,
please check logging and if you have any command i can exce it and show you te results
Router# show license
Index 1 Feature: adventerprise
        Period left: 8  weeks 3  days
        Period Used: 13 hours 4  minutes
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
Index 2 Feature: advipservices
        Period Used: 2  minutes 17 seconds
        License State: Active, Not in Use, EULA accepted
Index 3 Feature: ipbase
Index 4 Feature: avc
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 5 Feature: broadband
 --More--
og Buffer (4096 bytes):
APPLICATION-6-LICENSE_LEVEL: Module name = asr1001 Next reboot level = adventerprise and License = adventerprise
*Jul  8 01:04:45.132: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initializedSID Manager, starting initialization ...
*Jul  8 01:04:49.074: Notifications initializedSID Manager, completed initialization ...
*Jul  8 01:04:51.307: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jul  8 01:04:53.433: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jul  8 01:04:53.681: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jul  8 01:04:53.681: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jul  8 01:04:53.681: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jul  8 01:04:53.682: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jul  8 01:04:53.691: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL GigabitEthernet0 Physical Port Link Down
*Jul  8 01:04:53.709: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jul  8 01:04:53.869: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Jul  8 01:04:54.870: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 t
able-id 0x1E000001
*Jul  8 01:04:54.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jul  8 01:04:54.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jul  8 01:04:54.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jul  8 01:04:54.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jul  8 01:04:55.245: %IOSXE_RP_ALARM-2-PEM: ASSERT CRITICAL Power Supply Module 1 Power Supply Failure
*Jul  8 01:04:55.297: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jul  8 01:04:58.258: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3557788228 has been generated or imported by cryp
to config
*Jul  8 01:04:58.707: % Redundancy mode change to SSO
*Jul  8 01:04:58.707: %VOICE_HA-7-STATUS: NONE->SSO; SSO mode will not take effect until after a platform reload.
*Jul  8 01:04:58.718: %SYS-5-CONFIG_I: Configured from memory by console
*Jul  8 01:04:58.874: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F1
*Jul  8 01:04:58.874: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F1
*Jul  8 01:04:58.921: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 2
*Jul  8 01:04:59.010: %SYS-5-RESTART: System restarted --
*Jul  8 01:04:59.010: boot_env_str = adventerprise,all:asr1001;
*Jul  8 01:04:59.021: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jul  8 01:04:59.159: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3557788228.server has been generated or imported
by crypto-engine
*Jul  8 01:05:03.136: %SYS-6-BOOTTIME: Time taken to reboot after reload =  357 seconds
*Jul  8 01:05:04.015: %PLATFORM-4-LOWSPACE:  SD bootflash : low space alarm assert
*Jul  8 01:05:07.658: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Jul  8 01:05:13.375: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, li
ke NTP, can be obtained.
*Jul  8 01:05:43.934: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jul  8 01:05:43.934: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jul  8 01:09:50.893: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Jul  8 01:14:32.369: %SYS-5-CONFIG_I: Configured from console by console
*Jul  8 01:15:21.572: %SYS-5-CONFIG_I: Configured from console by console
*Jul  8 01:47:55.198: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 0 (0.0.0.0)), user
*Jul  8 02:02:28.269: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 0 (0.0.0.0)), user
Router#
Console into the router and reboot.  Post the entire boot-up process.
Router#relo
Router#reload
The following license(s) are transitioning, expiring or have expired.
Features with expired licenses may not work after Reload.
Feature: adventerprise                  ,Status: transition, Period Left: 8  wks 2  days
Proceed with reload? [confirm]
*Jul  9 13:29:43.927: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Jul  9 13:30:01.419: %PMA
Initializing Hardware ...
Calculating the ROMMON CRC ... CRC is correct
System Bootstrap, Version 16.9(5r), RELEASE SOFTWARE
Copyright (c) 1994-2019  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ASR1000-RP2 platform with 8388608 Kbytes of main memory
boot: unsupported boot device "bootstrab"
autoboot: boot failed, restarting...
Last reset cause: Watchdog/ICH
no valid BOOT image found
Final autoboot attempt from default boot device...
File size is 0x3acecdc1
Located asr1000rpx86-universalk9_noli.16.09.05.SPA.bin
Image size 986631617 inode num 12, bks cnt 240877 blk size 8*512
Boot image size = 986631617 (0x3acecdc1) bytes
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
        calculated 694349e4:7d98171b:427385ff:cf28523e:bc9c9b3c
        expected   694349e4:7d98171b:427385ff:cf28523e:bc9c9b3c
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           Cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
adding dispatch oce display chain to registrycisco ASR1006 (RP2) processor (revision RP2) with 4187925K/6147K bytes of memory.
3909632K bytes of USB flash at usb0:.
%INIT: waited 0 seconds for NVRAM to be available
Press RETURN to get started!
*Jul  9 13:34:59.730: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Jul  9 13:34:59.732: boot_env_str = adventerprise,all:asr1001;
*Jul  9 13:35:00.608: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Jul  9 13:35:00.639: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = asr1001 Next reboot level = adventerprise and
*Jul  9 13:35:05.584: %IOSD_INFRA-6-IFS_DEVICE_OIR: Device usb0 added
*Jul  9 13:35:05.770: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initializedSID Manager, starting initialization ...
*Jul  9 13:35:09.724: Notifications initializedSID Manager, completed initialization ...
*Jul  9 13:35:11.955: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jul  9 13:35:14.086: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jul  9 13:35:14.332: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jul  9 13:35:14.332: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jul  9 13:35:14.333: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jul  9 13:35:14.333: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jul  9 13:35:14.343: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL GigabitEthernet0 Physical Port Link Down
*Jul  9 13:35:14.353: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jul  9 13:35:14.539: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Jul  9 13:35:15.508: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 t
able-id 0x1E000001
*Jul  9 13:35:15.565: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jul  9 13:35:15.565: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jul  9 13:35:15.565: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jul  9 13:35:15.565: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jul  9 13:35:15.924: %IOSXE_RP_ALARM-2-PEM: ASSERT CRITICAL Power Supply Module 1 Power Supply Failure
*Jul  9 13:35:15.979: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jul  9 13:35:18.868: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3557788228 has been generated or imported by cryp
to config
*Jul  9 13:35:19.355: % Redundancy mode change to SSO
*Jul  9 13:35:19.355: %VOICE_HA-7-STATUS: NONE->SSO; SSO mode will not take effect until after a platform reload.
*Jul  9 13:35:19.361: %SYS-5-CONFIG_I: Configured from memory by console
*Jul  9 13:35:19.514: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F1
*Jul  9 13:35:19.514: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F1
*Jul  9 13:35:19.561: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 2
*Jul  9 13:35:19.660: %SYS-5-RESTART: System restarted --
*Jul  9 13:35:19.660: boot_env_str = adventerprise,all:asr1001;
*Jul  9 13:35:19.669: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jul  9 13:35:19.801: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3557788228.server has been generated or imported
by crypto-engine
*Jul  9 13:35:23.728: %SYS-6-BOOTTIME: Time taken to reboot after reload =  340 seconds
*Jul  9 13:35:24.664: %PLATFORM-4-LOWSPACE:  SD bootflash : low space alarm assert
*Jul  9 13:35:28.294: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Jul  9 13:35:34.028: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, li
Router>en
Router>enable
Router#
*Jul  9 13:36:06.249: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jul  9 13:36:06.249: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Router#
Router#upgrade rom-monitor filename harddisk:asr1000-rommon.163-2r.pkg all
Verifying the code signature of the ROMMON package...
Upgrade rom-monitor on Route-Processor 0
Target copying rom-monitor image file
File /tmp/rommon_upgrade/latest.bin is a FIPS ROMMON image
Checking upgrade image...
1114112+0 records in
2176+0 records out
1114112 bytes (1.1 MB, 1.1 MiB) copied, 0.858912 s, 1.3 MB/s
Upgrade image MD5 signature is 40284cafd63481e6f1ca71379420fbf9
Burning upgrade partition...
1114112+0 records out
1114112 bytes (1.1 MB, 1.1 MiB) copied, 28.0598 s, 39.7 kB/s
Checking upgrade partition...
1114112 bytes (1.1 MB, 1.1 MiB) copied, 3.28928 s, 339 kB/s
Upgrade flash partition MD5 signature is 40284cafd63481e6f1ca71379420fbf9
2097152+0 records in
2097152+0 records out
2097152 bytes (2.1 MB, 2.0 MiB) copied, 3.90026 s, 538 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 0.266858 s, 246 kB/s
Copying ROMMON environment
2097152 bytes (2.1 MB, 2.0 MiB) copied, 50.389 s, 41.6 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.57117 s, 41.7 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.56803 s, 41.8 kB/s
ROMMON upgrade complete.
To make the new ROMMON permanent, you must restart the RP.
Upgrade rom-monitor on Embedded-Service-Processor 1
cp: omitting directory '/'
md5sum: /: Is a directory
md5sum: /bootflash/EFI/UpdateCapsule/UpdateCapsuleFile.bin: No such file or directory
Secure update of the ROMMON image will occur after a reload.
2097152 bytes (2.1 MB, 2.0 MiB) copied, 5.64863 s, 371 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 0.300933 s, 218 kB/s
2097152 bytes (2.1 MB, 2.0 MiB) copied, 49.1603 s, 42.7 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.5432 s, 42.5 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.54075 s, 42.5 kB/s
To make the new ROMMON permanent, you must restart the linecard.
Upgrade rom-monitor on SPA-Inter-Processor 2
% Error connecting to SIP 2
Router#
Router#upgrade rom-monitor filename harddisk:asr1000-rommon.163-2r.pkg all​
Downgrading ROMMON?  That is very dangerous.  Try upgrading to 17.3(1r) instead.
Any reason why the router was upgraded to 16.9.5 when 16.9.8 was the last release?
That no reason to upgrade it , i only need to run router with any version
Upgrade the ROMMON (like what the other forum recommended) and upgrade the firmware of the router.  It could be a bug.
hello
 upgrade rom-monitor filename harddisk:asr1000-rommon.173-1r.SPA.pkg all​
2176+0 records out
1114112 bytes (1.1 MB, 1.1 MiB) copied, 0.894397 s, 1.2 MB/s
Upgrade image MD5 signature is 8e8c2a209ecbbc0881efb6afe41e7d6d
1114112 bytes (1.1 MB, 1.1 MiB) copied, 24.987 s, 44.6 kB/s
1114112 bytes (1.1 MB, 1.1 MiB) copied, 3.42712 s, 325 kB/s
Upgrade flash partition MD5 signature is 8e8c2a209ecbbc0881efb6afe41e7d6d
2097152 bytes (2.1 MB, 2.0 MiB) copied, 3.87787 s, 541 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 0.266576 s, 246 kB/s
2097152 bytes (2.1 MB, 2.0 MiB) copied, 44.7408 s, 46.9 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.40326 s, 46.7 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.39751 s, 46.9 kB/s
2097152 bytes (2.1 MB, 2.0 MiB) copied, 5.62272 s, 373 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 0.30424 s, 215 kB/s
2097152 bytes (2.1 MB, 2.0 MiB) copied, 47.4683 s, 44.2 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.48893 s, 44.0 kB/s
65536+0 records in
65536+0 records out
65536 bytes (66 kB, 64 KiB) copied, 1.4913 s, 43.9 kB/s
hello
this after upgrading rommon to 17.3
Router#reload
*Jul 10 22:34:26.669: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Jul 10 22:34:45.385: %PM
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM1
Rommon upgrade requested
Flash upgrade reset 1 in progress
System Bootstrap, Version 17.3(1r), RELEASE SOFTWARE
Copyright (c) 1994-2020 by cisco Systems, Inc.
Current image running: *Upgrade in progress* Boot ROM0
Last reset cause: BootRomUpgrade
Saving cur/min version to nvram 2
 ***          Incorrect BIOS parameters           ***
 *** Correcting the BIOS parameters and rebooting ***
Flash upgrade reset 2 in progress
2                             unknown               00:03:12
R0        ASR1000-RP2         ok, active            00:03:12
F1        ASR1000-ESP40       ok, active            00:03:12
P0        ASR1006-PWR-AC      ok                    00:02:17
P1        ASR1006-PWR-AC      ps, fail              00:02:16
2         N/A                 N/A
R0        14111801            17.3(1r)
Router#hw
Re-seat that SPA.
hi, same problem,
we install the cardline on another ASR1006 router , and it also show as unknown
Then it is confirmed that the SPA is faulty.
hi , Curious about the topic ,the cardline was working fine before upgrade rom and still now when insert cardline to router , all light is green
