7609 Module not powering up!
hurtheart
I have 7609-s chassis with WS-SUP720-3BXL engine.
#sh ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE7a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 22-Oct-12 05:54 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE7a, RELEASE SOFTWARE (fc1)
*********** uptime is 2 days, 2 hours, 20 minutes
Uptime for this control processor is 2 days, 2 hours, 19 minutes
System returned to ROM by reload at 18:51:26 PDT Tue Apr 28 2009 (SP by reload)
System restarted at 09:02:21 KST Sun Dec 15 2013
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRE7a.bin"
Last reload type: Normal Reload
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609-S (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX1315G8GB
SR71000 CPU at 600MHz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
14 Virtual Ethernet interfaces
84 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Two days agon I had reset the 7600-SIP-400 module existing on the same chassis bu issuing the following commands;
no power enable module 6
After that the module refused to power up and it shows as follows;
#show module 6
Mod Ports Card Type                              Model              Serial No.
  6    0  4-subslot SPA Interface Processor-400  7600-SIP-400       JAE13072WF1
Mod MAC addresses                       Hw    Fw           Sw           Status
  6  0024.c4dd.87c0 to 0024.c4dd.883f   2.6   Unknown      Unknown      PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
Mod  Online Diag Status
  6  Not Applicable
Any ideas!!!
10 Replies 10
Leo Laohoo
When you hardware reset the SPA, what were the events logged in the "sh log"?
Dec 15 09:46:11: %SNMP-5-MODULETRAP: Module 1 [Down] Trap
Dec 15 09:46:11: %OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
Dec 15 09:46:11: %SPA_OIR-6-OFFLINECARD: SPA (SPA-2X1GE-V2) offline in subslot 1/0
Dec 15 09:46:11: %SPA_OIR-6-OFFLINECARD: SPA (SPA-4XOC3-POS) offline in subslot 1/1
Dec 15 09:46:11: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (admin request)
Dec 15 09:56:26: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
Dec 15 09:56:26: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Module  Failed SCP dnld)
Dec 15 10:06:38: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
Dec 15 10:06:38: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Module  Failed SCP dnld)
Dec 15 10:16:50: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
Dec 15 10:16:50: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Module  Failed SCP dnld)
Dec 15 10:27:02: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
Dec 15 10:27:02: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Module  Failed SCP dnld)
Dec 15 10:37:14: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
Dec 15 10:37:14: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Module  Failed SCP dnld)
Ok, this is not good.
You have one of two possible scenarios:  One, the line card has failed and two, you have a rare backplane fault.
The best way to determine which one is to insert the line card into a different slot.  If the same error message comes up, RMA the line card.
I would like to thank you Leo for your time and response.
The strange thing is that, I have another SPA card attached to the same chassis, I have moved it to another complete different chassis and got the same exact behavior on the new chassis!!! So, I'm suspecting that I'm doing something wrong or I'm missing something!
What do you think?
Thanks again for your support.
It is also not supported with a Supervisor Engine 720 PFC3A, or in PFC3A mode.
Can you check your supervisor card is not PFC2 or PFC3A?
Is this what your asking for?
#sh module | i PFC
  5  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1310LCZH  1.10   Ok
What happens to the SPA if you REMOVE the SPA-2X1GE-V2?
Well, I havn't tried to do anything with the sup-slots since I thought the proble is with the whole card!
I forgot to mention that before reseting the card it was working perfectly on the same chassis with the same sup and the same IOS. I haven't changed anything!
Any ideas guys!
