Enterprise Load balancer
Hari Prasad
Dear Team,
I would like to know about Enterprise Load balancer hardware and software which is recommended for cisco devices and how its work in enterprise network where i have 3 ISP and also suggest me best hardware vendor for load balancer.
Kindly help.
hari
Please rate helpful posts
Thanks, Hari Prasad
Collin Clark
Cisco recommends Citrix Netscaler. We use F5 and have not had any problems.
Sent from Cisco Technical Support Android App
Thanks Collin ,
Could  you briefly explain its work.
hari
Thanks, Hari Prasad
Dear Hari,
I think F5 is the market leader in Loadbalancers
The basic idea of loadbalncers is to have redundancy ,fault tolernce and best performance of application. Multiple physical servers are grouped into a virtual Ip address in the loadbalancer .The clinets will be accessing the service torugh this virtual IP address.  Traffic to the service will be hitting the Loadbalancer and loadbalancer will be distribute the packet to different servers in the group based on the loadbalancing method configured. (ex round-robin, based on weight, based on load of the servers)
Hopes this helps
Thanks ***Please rate helpful posts***
Shanil
Thanks Shanil for resolving the query.
hari
Thanks, Hari Prasad
