8.8.8.8 reachability issue
sankarmay
Dear All,
I have one query.
I am using one public IP as a lan segment and i am trying to access internet.
internet is working fine but i am unable to access 8.8.8.8 Ip but i ma able to access 4.2.2.2 with source of lan but i am able to ping 8.8.8.8 without source of LAN.
Can anyone explain where could be the issue.
I am not doing any nating.
6 Replies 6
Harold Ritter
Are you pinging from the router of from the workstation? You could try enabling "debug ip icmp" on the router and then "ping 8.8.8.8 source <lan interface name>" and see if you receive more information on the reason why it doesn't work.
Julio E. Moisa
Is there any firewall or ACL?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
ACL is there for redistributing the routes.
The IP 8.8.8.8 should be known through the default route (last resort) so the issue could be a filtering method between the users and edge routers, have tried to ping that IP from the edge router?
Hello
Would be easier to be able view your configuration - is that applicable?
res
Paul
Kind Regards
Paul
Hi dude:
I'm from Mexico and sometimes I had the same issues. According to my Service Provider (ISP Telmex), Google was having problems with them due to the excessive traffic generated by users tried to reach 8.8.8.8
By the way, I recommend doing ping to 208.67.222.222 (Cisco DNS Services)
Regards .
