802.1Q and dot1Q question
gopal_4476
I have doubt on 802.1Q and dot1q. What is the differece between these two and which one is the layer 2 protocol??
Gopal
pkhatri
Level 11
Level 11
Hi Gopal,
They are one and the same thing...dot1q is simply used as an abbreviation for 802.1q.
Pls do remember to rate posts.
Paresh
Hi pkhatri,
thanks for your immediate reply
still i am confused... could you explain it in detail
Gopal
Gopal,
What I am saying is that there is no difference between saying 802.1q and dot1q - they refer to the same thing.
The IEEE 802.1q specifies a 4-byte header which can be used in order to tag ethernet frames in order to associated them with a virtual LAN. The actual VLAN ID is 12 bits, giving you a theoretical maximum of 4096 VLANs.
Pls do remember to rate posts that help.
Paresh
csco10837896
802.1Q & dot1q one at same.
802.1Q its IEEE standard .
When you are trying to configure on switch command is dot1q
Pls Rate this post
Yogesh
