802.1Q VLAN Trunk Configuration
s76602061
I think there are 2 ways 802.1Q VLAN Trunk Configuration as following.
My understanding is just configuration is different but function is same,
and [Pattern 1] is used for L3 port, and [Pattern 2] is used for L2 port.
Does my understanding is correct?
[Pattern 1]
interface GigabitEthernet1.1
encapsulation dot1Q 100
ip address xx.xx.xx.xx xx.xx.xx.xx
[Pattern 2]
switchport trunk allowed vlan 100
switchport mode trunk
interface Vlan100
9 Replies 9
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Are you talking switches or routers?
On a switch, pattern 2 can support L3, as the switch might be hosting SVIs.
On a router, a variation of pattern 1 would be used.  The encapsulation would be applied to the main interface, and then you can define subinterfaces with IPs (although the main interface can have an IP too).
Hi, thank you so much for your comment. It is really appreciated.
You are most welcome,
Masoud
I am just adding to Joseph answer.
Pattern 1 is configured on the router interfaces while pattern 2 is cofigured on switch interfaces. In both case, the main interface (interface GigabitEthernet1) is trunk.  interface GigabitEthernet1.1 in pattern 1 is called subinterface and interface Vlan100 in pattern2 is called SVI.
On higher level switches and routers, you can find both configurations depending on the types of interfaces.
subinterface is a division of one physical interface into multiple logical interfaces.
SVI is a virual L3 interface.
Masoud
Thank you very much for your additional comment. It is really helpful for detail understanding.
mehulnangru
[Pattern 1] is used for L3 port -
Yes , this kind of configuration for a sub interface and this is done on routers only and yes router is a layer 3 device,
[Pattern 2] is used for L2 port. -
I slightly contradict with you here . First part of pattern 2 could be for a Trunk link between a switch<>Router or may be a switch<>switch .
HOWEVER
part 2 of pattern 2 is a layer 3 interface on a switch (called as SVI - switches virtual interface).
Hope I have been able to explain in simple language .
Thank you very much for your detailed comment, I have also agreed that your comment for [Pattern2].
Ganesh Hariharan
[Pattern 1]
GI :- Yes , It is router main interface which is L3 and used for sub interface configuration.
[Pattern 2]
interface Vlan100
GI:- You are making Gig1 port as layer 2 port with trunking VLANS till router port.
Having interface Vlan 100 , you are creating L3 SVI to route traffic to other Layer 3 interface thus eliminating the need for a physical router.
Hope it Helps..
-GI
thank you for your detailed answer, it same as my understanding. thank you.
