827 ADSL Config
vantipov
I need to connect 827 to ADSL with a static WAN IP. I am having a problem with NAT. I need to nat private scope to one public. Bellow is my config.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname r1
enable secret 5 *******
ip subnet-zero
ip name-server 216.165.129.157
ip name-server 134.215.200.126
interface Ethernet0
ip address 192.168.35.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description *** To WR ***
ip address 60.10.32.90 255.255.255.252
pvc 0/35
encapsulation aal5snap
ip nat inside source list 1 interface ATM0.1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 60.10.32.89
ip http server
access-list 1 permit 192.168.35.0 0.0.0.255 log
line con 0
stopbits 1
line vty 0 4
exec-timeout 0 0
password 7 *********
login
scheduler max-task-time 5000
end
your config looks ok, you are just missing one thing:
-->ip nat outside
pvc 0/35
Can you add this to your configuration and see if that works ?
GP
You are right, I left that out. I will put this and let you know. Thanks.
GP, That was it. Thanks a bunch.
