827 IOS Version
danletkeman
What is the newest ios available for an 827 router? I'm having some trouble with lockups and some of the results from snmp.
This is what i'm currently running:
IOS (tm) C820 Software (C820-K9OSY6-M), Version 12.2(15)T5, RELEASE SOFTWARE (f
c1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 12-Jun-03 00:24 by eaarmas
Image text-base: 0x80013148, data-base: 0x80A5AE7C
ROM: System Bootstrap, Version 12.1(1r)XB1, RELEASE SOFTWARE (fc1)
dsl02 uptime is 19 hours, 44 minutes
System image file is "flash:c820-k9osy6-mz.122-15.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
CISCO C827 (MPC855T) processor (revision 0x801) with 23552K/1024K bytes of memor
y.
Processor board ID JAD05350L9W (3566344292), with hardware revision 0000
CPU rev number 5
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Dan.
Collin Clark
The latest 12.2 code is 12.2.15T15.
HTH and please rate.
Do you know if the 12.3 code works on an 827. Or do you have a link to a page that could tell me what works and what doesn't?
Dan.
There is IOS in both 12.3 and 12.4 trains. Feature navigator will tell you what features are supported. You will need a CCO account to access it.
