857 Trouble
battanc
New installed 857 in the branch office; I have some trouble:
1) I have a VPN to a PIX-506 in the main site; VPN is UP, from the branch I can connect to the server in the Main site (alle services). From the central site I can only ping the PC's in the branch, but I can not connect via RDP (port 3389), while all ports seam to be open - NO FireWall function activated on the Router.
2) I am not able to manage the router from remote - how to configure ?
Attached:
MAIN PIX: PIX-TN_051213.txt
Remote Router: Rt-CUrov_051213.txt
Show Version: ShVer.txt
Best Regards
your PIX configuration looks ok. Can you try and add the following command to your remote router:
ip nat inside source static tcp X.X.X.X 88.32.72.202 3389 extendable
where X.X.X.X is the IP address of one of your PCs ?
And then try to connect through RDP again (to that specific PC) ?
GP
