860 Series Issues
Hi everyone,
I'm having some trouble configuring a Cisco 860 series as a WAN router for a satellite office. I have the device here ready to be installed, though in testing I'm not able to get WAN connectivity in my test environment from the LAN ports.
Basically, LAN clients (192.168.1.1/24) on FE0,1,2,3 & GE0 need to be able to access the internet via WAN port GE1 (Statically assigned address of 10.0.0.11/24 with a G/W of 10.0.0.1).
For testing purposes, clients have statically assigned addresses within the 192.168.1.1/24 range and their gateway set to 192.168.1.1 (the 860 series). I am aware that FE0,1,2,3 in the attached config are disabled, at the moment I am connected to GE0.
I can ping from the WAN port to 8.8.8.8 (Good), but not able to ping from any LAN clients to 8.8.8.8 (Bad).
I've attached a copy of the config file with sensitive information removed, any help would be appreciated.
Cheers,
Anthony
MD KAFINUZZAMAN
Hi anthonyTEC ,
ip nat inside source list nat-list interface GigabitEthernet1 overload
Where is nat-list ?????
Kafi
6 Replies 6
Tom Watts
 description PrimaryWAN
 ip address 10.0.0.11 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
interface GigabitEthernet0
 no ip address
ip nat inside should be used on gigeth0.
Basic template or rules for client to connect would be the following-
1.    enable
2.    configure terminal
3.    ip nat pool name start-ip end-ip {netmask netmask | prefix-length prefix-length}
4.    access-list access-list-number permit source [source-wildcard]
5.    ip nat inside source list access-list-number pool name overload
6.    interface type number
7.    ip address ip-address mask
8.    ip nat inside
9.    exit
10.    interface type number
11.    ip address ip-address mask
12.    ip nat outside
13.    end
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Sorry I don't understand why I would put "ip nat inside" on the physical port when I've already assigned it to the VLAN? My understanding is due to being a L2 router I need to configure the VLAN and not the ports.
I can ping the 192.168.1.1 from clients and access the http secure-server on the address which to me means that I've at least got that part right.
Cheers,
Anthony
There's still nothing configured on your gig e port. I don't believe the router is assuming the vlan. Try to set as access port in VLAN 1.
show vlan-switch reports:
VLAN Name                             Status    Ports
1    default                          active    Fa0, Fa1, Fa2, Fa3, Gi0
So definitely a member of VLAN1.
Cheers,
Anthony
MD KAFINUZZAMAN
Hi anthonyTEC ,
Kafi
Uh, god damn it... changed rule to:
ip nat inside source list 1 interface GigabitEthernet1 overload
and created an ACL...
access-list 1 permit 192.1681.0 0.0.0.255
and now I'm getting:
Reply from 8.8.8.8: bytes=32 time=23ms TTL=56
Thanks for your help, I'll go find myself a hole now!
Cheers,
Anthony
