867vae ATM errors
robway999
Hi All,
i am using an 867vae router for my home DSL PPPOA connection. Everything works resonably well and bar a handfull of crc and header errors the connection is stable... but if i do a debug atm errors i get a constant stream of errors as shown below...
I have searched extensively on google for a clue to what this error means but have had no joy...
help please
Feb 26 19:36:02.382:  bcm6300_atmsar_dequeue_pak fail bcm6300_atmsar_safe_start 1381  pak 0
Feb 26 19:36:02.446:  bcm6300_atmsar_dequeue_pak fail bcm6300_atmsar_safe_start 1381  pak 0
Feb 26 19:36:02.458:  bcm6300_atmsar_dequeue_pak fail bcm6300_atmsar_safe_start 1381  pak 0
sh run
HOME#sh run
ip inspect WAAS flush-timeout 10
no ip bootp server
no ip domain lookup
ip domain name *******
ip name-server 129.250.35.250
ip name-server 4.2.2.5
ip cef
ipv6 multicast rpf use-bgp
no ipv6 cef
archive
log config
  hidekeys
username ********* privilege 15 secret 4 JCy3fxBePjv4JBTSy5.j.ACEMV4pOT20ovlk8dm5M/o
controller VDSL 0
operating mode adsl2+ annex A
firmware filename flash:VAE_AB_35j_23jE.bin
modem ukfeature
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Null0
no ip unreachables
interface ATM0
no ip address
ip nat outside
no ip virtual-reassembly in
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address dhcp
pvc 0/38
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
description WAP
switchport mode trunk
no ip address
duplex full
speed 100
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
duplex full
speed 100
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
ip address 1.1.1.1 255.255.255.0
ip nat inside
interface Dialer0
description ***External ADSL Interface***
ip address negotiated
ip access-group 101 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname *****
ppp chap password 0 *****
ppp ipcp route default
no ip classless
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source list 3 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
sh controllers vdsl 0
Controller VDSL 0 is UP
Daemon Status:           NA
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'P   '
Chip Vendor Specific:   0x0000                   0x0000
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   'P   '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0xB500
Serial Number Near:    GMK1217004F 867VAE- 15.3(1)
Serial Number Far:
Modem Version Near:    15.3(1)
Modem Version Far:     0x0000
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         ADSL2+
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
SRA:                     disabled                        disabled
SRA count:              0                       0
Bit swap:                enabled                         enabled
Bit swap count:         397                     0
Line Attenuation:        22.5 dB                 12.5 dB
Signal Attenuation:      24.3 dB                 12.8 dB
Noise Margin:             9.0 dB                  7.3 dB
Attainable Rate:        14108 kbits/s            1060 kbits/s
Actual Power:            19.0 dBm                12.6 dBm
Total FECC:             318                      0
Total ES:               3                        0
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              28                       28
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            user config     flash:VAE_AB_35j_23jE.bin (0)
Modem FW  Version:      23j
Modem PHY Version:      A2pv6C035j.d23j
Vendor Version:         Ap6v35j.23j 68
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            12490             0              1023
SRA Previous Speed:       0                0             0                 0
Total Cells:              0        148775362             0          12182652
User Cells:               0          1331727             0           1101039
Reed-Solomon EC:          0              318             0                 0
CRC Errors:               0                6             0                 0
Header Errors:            0               46             0                 0
Interleave (ms):       0.00             9.12          0.00              0.24
Actual INP:            0.00             0.63          0.00              0.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
Many thanks in advance
Rob
paolo bevilacqua
This kind of messages, obtained during debug, are not indicative of anything wrong.
If you want to optimize you configuration a little, disable 'virtual reassembly'.
Thanks Paolo
Previously ive only used 1801/1841/877 routers and havent seen that error before! I assumed my config must be bad as its a little different using the VDSL controller.
I have disabled the virtual-reassembly as you suggested.
Rob
Also since you are using PPP and not PPPoE, you can probably reset MTU and TCP MSS to default.
Please remember to rate useful posts clicking on the stars below.
