871 router NAT troubleshooting
erickppp1
Guys
I've been struggling with some configs on this router I'm setting up for a friend and just can't get Internet to work
- Wifi association works fine
- The router can ping the internet fine and tried with 4.2.2.2
- Client is getting IP address and gateway info fine
- Client can ping default gw but not an internet address like 4.2.2.2
- This router's gateway is 10.5.5.168 and that part of the network is fine and tested out
jaybuddy#wr t
Building configuration...
Current configuration : 3157 bytes
! Last configuration change at 04:22:07 UTC Fri Mar 1 2002
version 15.1
no service pad
hostname jaybuddy
boot-start-marker
boot-end-marker
enable secret 4 U3m4oAxPL6U2QZg5dXhsBS7y6IpWl4NjAhg1.bHP0Vo
aaa new-model
aaa session-id common
dot11 syslog
dot11 ssid GUESTRITS
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 test2231
dot11 ssid jaybuddy
vlan 1
authentication open
ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp pool GUESTRITS
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
no ip domain lookup
no ipv6 cef
bridge irb
interface FastEthernet0
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid GUESTRITS
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 2
interface BVI1
ip address 10.0.0.2 255.255.255.0
interface BVI2
ip nat inside
ip nat enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list 100 interface FastEthernet4 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
alias exec si show ip int brief
alias exec sir show ip route
alias exec fi show running-config | include
alias exec fb show running-config | begin
alias exec sri show run interface
alias exec sal show access-list
alias exec sib show ip bgp
alias exec sio show ip ospf
alias exec sie show ip eigrp top
alias exec srm show route-map
privilege exec all level 5 configure
privilege exec level 5 reload
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler max-task-time 5000
end
jaybuddy#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.0.0.2        YES manual up                    up
BVI2                       192.168.1.1     YES manual up                    up
Dot11Radio0                unassigned      YES unset  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
Dot11Radio0.2              unassigned      YES unset  up                    up
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              10.5.5.106      YES DHCP   up                    up
NVI0                       192.168.1.1     YES unset  up                    up
Vlan1                      unassigned      YES unset  up                    up
Vlan2                      unassigned      YES unset  up                    down
jaybuddy# show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 10.5.5.168 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 10.5.5.168
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.0.0.0/24 is directly connected, BVI1
L        10.0.0.2/32 is directly connected, BVI1
C        10.5.5.0/24 is directly connected, FastEthernet4
L        10.5.5.106/32 is directly connected, FastEthernet4
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, BVI2
L        192.168.1.1/32 is directly connected, BVI2
If anybody can help out, I'll appreciate it
jawad-mukhtar
Level 4
Level 4
dns-server x.x.x.x
ip name-server DNS1 X.X.X.X
ip name-server DNS2 X.X.X.X
Do Rate Post If u find helpful
Jawad
Unfortuantely that didn't help - I know you've added DNS info in but right now, the ping itself or L3 isn't working so want to get that working before I get to L4. This definitely seems a problem with NAT
Because you have "ip nat outside" on the wan interface, you'll want to remove "ip nat enable" on the bvi.
interface BVI2
ip nat inside
ip nat enable
This is a different way of doing nat. Your nat statement also references a "nat enabled" statement instead of a directional statement. It may be easier to remove "ip nat outside" on fa4 and put in "ip nat enable" on that interface as well.
Otherwise, so to sum it up, you need to do one of two things:
1.) Change fa4 to "ip nat enable" and remove "ip nat outside"
OR
2.) Remove "ip nat enable" from the BVI AND
3.) Change the nat state to support point 2 to "ip nat inside soure list 100 interfa fa4 overload"
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
no ip address
interfaceFastEtherne0.1
 bridge-group 1
interfaceFastEtherne0.2
 bridge-group 2
***Do Rate All Helpful Posts***
Jawad
