ASR 1001 PLATFORM-4-ELEMENT_WARNING: SIP0
jingt0829
Dear All,
We are constantly having the following warning on our ASR 1001. We are not sure that these warnings mean.
Oct 26  09:37:10.335: %PLATFORM-4-ELEMENT_WARNING: SIP0: smand:  RP/0: 5-Minute  Load Average value 9.26 exceeds warning level 8.00
Oct 26 09:47:11.779: %PLATFORM-4-ELEMENT_WARNING: SIP0: smand:   RP/0: 5-Minute Load Average value 9.08 exceeds warning level 8.00
Oct  26 09:57:13.611: %PLATFORM-4-ELEMENT_WARNING: SIP0: smand:  RP/0:  5-Minute Load Average value 9.21 exceeds warning level 8.00
We also found that the router is a bit laggy. Pings from/to this router are having high latency.
Any help will be appreciated.
Jing
Hi Jing,
Yes, reload fixes the problem till next OIR or reset even on SPA. Removing the card is not required, it will be working fine after the router reload.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
9 Replies 9
Ivan Shirshin
Hi Jing,
Which release are you using?
Please attach the outputs of:
     show version
     show platform
     show platform software process slot rp active monitor
     show platform software status control-processor brief
Such messages could be seen when there is a lack of resources on RP. Did something change in the period the errors occurred first time? E.g. more incoming traffic, OIR, etc.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
Thanks for looking into this issue.
r1-2-asr-king-mel#sh version
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(1)S1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 15-Feb-12 21:55 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
r1-2-asr-king-mel uptime is 33 weeks, 1 day, 11 hours, 19 minutes
Uptime for this control processor is 33 weeks, 1 day, 11 hours, 20 minutes
System returned to ROM by reload at 16:59:59 AEDST Sun Mar 11 2012
System restarted at 01:03:16 AEDST Mon Mar 12 2012
System image file is "bootflash:/asr1001-universalk9.03.05.01.S.152-1.S1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Info:
License UDI:
Device# PID                     SN                      UDI
*0      ASR1001                 JAE160201T0             ASR1001:JAE160201T0
License Package Information for Module:'asr1001'
Module name   Image level          Pri   Config Valid license
asr1001       adventerprise        1     NO     adventerprise
              advipservices        2     NO     advipservices
              ipbase               3     NO     ipbase
Module name   Current Level        Reboot Level
asr1001       adventerprise        adventerprise
cisco ASR1001 (1RU) processor with 1179689K/6147K bytes of memory.
9 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
r1-2-asr-king-mel#sh platform
Chassis type: ASR1001
Slot      Type                State                 Insert time (ago)
0         ASR1001             ok                    33w1d
0/0      ASR1001             ok                    33w1d
0/1      SPA-5X1GE-V2        ok                    4d00h
R0        ASR1001             ok, active            33w1d
F0        ASR1001             ok, active            33w1d
P0        ASR1001-PWR-AC      ok                    33w1d
P1        ASR1001-PWR-AC      ok                    33w1d
P2        ASR1001-FANTRAY     ok                    33w1d
Slot      CPLD Version        Firmware Version
0         10042219            15.0(1r)S
R0        10042219            15.0(1r)S
F0        10042219            15.0(1r)S
r1-2-asr-king-mel#sh platform software process slot rp active monitor
top - 12:24:09 up 232 days, 11:22,  0 users,  load average: 8.47, 8.75, 8.95
Tasks: 227 total,  11 running, 216 sleeping,   0 stopped,   0 zombie
Cpu(s):  4.4%us,  6.9%sy,  0.0%ni, 88.6%id,  0.0%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:   3944724k total,  3862828k used,    81896k free,   107652k buffers
Swap:        0k total,        0k used,        0k free,  1479860k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
3264 root      20   0 18100 8092 5840 R   98  0.2  13432:06 cmcc
32502 root      20   0  1612  512  452 R    7  0.0   0:00.04 fuser
3263 root      20   0  4832 3560 1044 S    4  0.1 528:03.23 btrace_rotate.s
28319 root      20   0 2283m 1.2g 110m S    2 30.9  10559:18 linux_iosd-imag
    1 root      20   0  1816  516  440 S    0  0.0   0:19.91 init
    2 root      15  -5     0    0    0 S    0  0.0   0:00.04 kthreadd
    3 root      RT  -5     0    0    0 S    0  0.0   0:57.77 migration/0
    4 root      15  -5     0    0    0 R    0  0.0   4:46.36 ksoftirqd/0
    5 root      RT  -5     0    0    0 S    0  0.0   0:00.01 watchdog/0
    6 root      RT  -5     0    0    0 S    0  0.0   1:14.28 migration/1
    7 root      15  -5     0    0    0 S    0  0.0   5:18.25 ksoftirqd/1
    8 root      RT  -5     0    0    0 S    0  0.0   0:00.00 watchdog/1
    9 root      15  -5     0    0    0 S    0  0.0   0:36.86 events/0
   10 root      15  -5     0    0    0 S    0  0.0   0:03.91 events/1
   11 root      15  -5     0    0    0 S    0  0.0   0:00.01 khelper
   14 root      15  -5     0    0    0 S    0  0.0   0:00.00 netns
   59 root      15  -5     0    0    0 S    0  0.0   0:00.06 kblockd/0
   60 root      15  -5     0    0    0 S    0  0.0   0:00.06 kblockd/1
   61 root      15  -5     0    0    0 S    0  0.0   0:00.00 kacpid
   62 root      15  -5     0    0    0 S    0  0.0   0:00.00 kacpi_notify
  143 root      15  -5     0    0    0 S    0  0.0   0:00.00 cqueue
  147 root      15  -5     0    0    0 S    0  0.0   0:00.00 ata/0
  148 root      15  -5     0    0    0 S    0  0.0   0:00.00 ata/1
  149 root      15  -5     0    0    0 S    0  0.0   0:00.00 ata_aux
  150 root      15  -5     0    0    0 S    0  0.0   0:00.00 ksuspend_usbd
  155 root      15  -5     0    0    0 S    0  0.0   0:00.00 khubd
  158 root      15  -5     0    0    0 S    0  0.0   0:00.00 kseriod
  211 root      15  -5     0    0    0 S    0  0.0   0:00.99 kswapd0
  255 root      15  -5     0    0    0 S    0  0.0   0:00.00 aio/0
  256 root      15  -5     0    0    0 S    0  0.0   0:00.00 aio/1
  312 root      14  -6  3688 2428 1044 S    0  0.1   0:00.06 pman.sh
  439 root      20   0  564m  13m 5808 S    0  0.3  12:37.36 cpp_ha_top_leve
  478 root      20   0  542m 9940 4836 S    0  0.3   0:00.04 cpp_cdm_svr
  528 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
  629 root      14  -6  3692 2428 1040 S    0  0.1   0:00.07 pman.sh
  709 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
  857 root      20   0 15044 6480 3580 S    0  0.2   4:56.84 emd
  928 root      14  -6  3688 2424 1040 S    0  0.1   0:00.06 pman.sh
1076 root      15  -5     0    0    0 S    0  0.0   0:00.00 scsi_eh_0
1078 root      15  -5     0    0    0 S    0  0.0   0:00.00 scsi_eh_1
1080 root      15  -5     0    0    0 S    0  0.0   0:00.00 scsi_eh_2
1082 root      15  -5     0    0    0 S    0  0.0   0:00.00 scsi_eh_3
1103 root      15  -5     0    0    0 S    0  0.0   0:00.00 scsi_eh_4
1104 root      15  -5     0    0    0 S    0  0.0  13:36.02 usb-storage
1118 root      14  -6  3688 2428 1040 S    0  0.1   0:00.06 pman.sh
1131 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
1227 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
1518 root      20   0  671m  33m 6524 S    0  0.9   0:34.81 cpp_sp_svr
1530 root      14  -6  3688 2424 1040 S    0  0.1   0:00.07 pman.sh
1546 root      20   0 1563m 395m  34m R    0 10.3 351:35.53 fman_fp_image
1668 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
1767 root      20   0  3764 2528 1060 S    0  0.1   0:00.32 pvp.sh
1865 root      20   0  4672 1588 1212 S    0  0.0   0:00.00 rotee
1968 root      20   0 13872 4852 2876 S    0  0.1   2:17.17 hman
2079 root      20   0 11332 4708 2768 S    0  0.1   0:43.47 plogd
2214 root      20   0  1720  500  404 S    0  0.0   0:00.00 inotifywait
2266 root      15  -5     0    0    0 S    0  0.0   0:00.00 rpciod/0
2269 root      15  -5     0    0    0 S    0  0.0   0:00.00 rpciod/1
2278 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsiod
2358 root       0 -20     0    0    0 S    0  0.0   0:00.44 loop0
2426 root      14  -6  3676 2412 1040 S    0  0.1   0:00.06 pman.sh
2490 bin       20   0  1764  608  484 S    0  0.0   0:00.00 portmap
2544 root       0 -20     0    0    0 S    0  0.0   0:00.01 loop1
2581 root       0 -20     0    0    0 S    0  0.0   0:00.04 loop2
2618 root       0 -20     0    0    0 S    0  0.0   0:00.11 loop3
2655 root       0 -20     0    0    0 S    0  0.0   0:00.00 loop4
2680 root      14  -6  3680 2420 1040 S    0  0.1   0:00.06 pman.sh
2764 root       0 -20     0    0    0 S    0  0.0   0:00.05 loop5
2801 root       0 -20     0    0    0 S    0  0.0   0:00.00 loop6
2853 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
2874 root       0 -20     0    0    0 S    0  0.0   0:00.02 loop7
2892 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
3154 root      14  -6  3680 2420 1040 S    0  0.1   0:00.07 pman.sh
3301 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
3512 root      20   0  4672 1584 1220 S    0  0.0   0:00.00 rotee
3564 root      20   0 15032 6472 3580 S    0  0.2   4:49.41 emd
3575 root      14  -6  3676 2412 1040 S    0  0.1   0:00.05 pman.sh
3668 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
3748 root      20   0 13872 4896 2920 S    0  0.1   2:16.54 hman
3944 root      14  -6  3680 2416 1040 S    0  0.1   0:00.06 pman.sh
4131 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
4268 root      20   0 12768 5880 4172 R    0  0.1 123:33.97 imccd
4586 root      14  -6  3676 2416 1040 S    0  0.1   0:00.05 pman.sh
4668 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
4762 root      20   0 11332 4732 2796 S    0  0.1   0:40.81 plogd
7515 root      20   0  2520 1208 1008 S    0  0.0   0:00.00 mcp_chvrf.sh
7516 root      20   0  2520 1208 1008 S    0  0.0   0:00.00 mcp_chvrf.sh
7517 root      20   0  1820  532  452 S    0  0.0   0:00.00 sntp
7518 root      20   0  2940 1660 1040 S    0  0.0   0:00.02 rollback_timer.
7520 root      20   0  2132  792  680 S    0  0.0   0:00.00 xinetd
7523 root      20   0  2908 1632 1040 S    0  0.0   0:00.01 oom.sh
7524 root      20   0  4972 3708 1056 S    0  0.1  20:01.18 chasync.sh
7525 root      20   0  3408 2128 1040 S    0  0.1   0:00.03 iptbl.sh
7526 root      20   0  2508 1156  964 S    0  0.0   0:00.00 libvirtd.sh
7537 root      20   0  2132  796  680 S    0  0.0   0:00.00 xinetd
7562 root      20   0 80944 2388 1564 S    0  0.1   0:00.38 libvirtd
7695 root      20   0  4672 1572 1208 S    0  0.0   0:00.00 rotee
7735 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
7743 root      20   0  1716  496  404 S    0  0.0   0:00.00 inotifywait
7754 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
7772 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
7776 root      20   0  4428 2400  288 S    0  0.1   3:50.28 oom.sh
7792 root      20   0  1716  508  416 S    0  0.0   0:00.00 inotifywait
8247 root      14  -6  3676 2416 1040 S    0  0.1   0:00.07 pman.sh
8335 root      20   0  4672 1584 1208 S    0  0.0   0:00.00 rotee
8402 root      20   0  178m  53m  31m R    0  1.4 411:34.42 mcpcc-lc-ms
9249 root      14  -6  3676 2412 1040 S    0  0.1   0:00.05 pman.sh
9340 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
9437 root      20   0  178m  53m  31m R    0  1.4  86:18.71 mcpcc-lc-ms
13283 root      16  -4  1716  484  364 S    0  0.0   0:01.34 udevd
14752 root      20   0  2516 1224 1028 S    0  0.0   0:00.04 auxport.sh
14783 root      20   0  3892 2684 1100 S    0  0.1   8:46.70 reflector.sh
14786 root      20   0  3904 2688 1100 S    0  0.1   0:00.60 droputil.sh
14866 root      20   0 24504 1368  960 S    0  0.0   0:03.30 automount
14930 root      15  -5     0    0    0 S    0  0.0   0:00.00 lockd
14931 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14932 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14933 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14934 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14935 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14936 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14937 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14938 root      15  -5     0    0    0 S    0  0.0   0:00.00 nfsd
14940 root      20   0  1748  296  180 S    0  0.0   0:00.00 rpc.mountd
15019 root       0 -20     0    0    0 S    0  0.0   0:00.00 loop8
15058 root      15  -5     0    0    0 R    0  0.0   0:40.47 lsmpi-refill
15059 root      15  -5     0    0    0 S    0  0.0  13:40.99 lsmpi-xmit
15060 root      15  -5     0    0    0 R    0  0.0  27:29.69 lsmpi-rx
15443 root      15  -5     0    0    0 S    0  0.0   0:07.02 ddr_err_monitor
15460 root      15  -5     0    0    0 S    0  0.0   0:00.95 mtdblockd
15582 root      30  10     0    0    0 S    0  0.0   0:00.32 jffs2_gcd_mtd6
15588 root      30  10     0    0    0 S    0  0.0   0:00.04 jffs2_gcd_mtd7
15592 root      30  10     0    0    0 S    0  0.0   0:00.00 jffs2_gcd_mtd2
15596 root      30  10     0    0    0 S    0  0.0   0:00.00 jffs2_gcd_mtd3
15600 root      30  10     0    0    0 S    0  0.0   0:00.00 jffs2_gcd_mtd4
15604 root      30  10     0    0    0 S    0  0.0   0:00.00 jffs2_gcd_mtd5
15732 root      20   0     0    0    0 R    0  0.0   3:40.03 cavium
15795 root      15  -5     0    0    0 S    0  0.0   0:00.00 scansta
16447 root      20   0  4672 1592 1216 S    0  0.0   0:22.34 rotee
16451 root      20   0  4672 1588 1212 S    0  0.0   0:00.01 rotee
16492 root      20   0  1720  520  416 S    0  0.0   0:00.00 inotifywait
16495 root      20   0  1720  528  416 S    0  0.0   0:00.01 inotifywait
16948 root      20   0  2132  756  636 S    0  0.0   0:00.00 xinetd
16950 root      20   0  2132  708  596 S    0  0.0   0:00.00 xinetd
22753 root      20   0  1612  408  340 S    0  0.0   0:00.13 klogd
22761 root      20   0  3484 2216 1048 S    0  0.1   0:00.04 psvp.sh
22797 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
22808 root      20   0  1720  500  404 S    0  0.0   0:00.00 inotifywait
22812 root      20   0  3784 2556 1064 S    0  0.1   0:00.51 pvp.sh
22857 root      20   0  4672 1580 1212 S    0  0.0   0:00.00 rotee
23050 root      20   0  1720  500  404 S    0  0.0   0:00.00 inotifywait
23120 root      14  -6  3728 2468 1044 S    0  0.1   0:00.08 pman.sh
23209 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
23230 root      14  -6  3708 2448 1044 S    0  0.1   0:00.07 pman.sh
23337 root      14  -6  3712 2452 1044 S    0  0.1   0:00.08 pman.sh
23341 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
23442 root      14  -6  3712 2452 1044 S    0  0.1   0:00.08 pman.sh
23474 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
23631 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
23941 root      14  -6  3708 2452 1044 S    0  0.1   0:00.09 pman.sh
23957 root      20   0 48360  11m 8292 S    0  0.3  44:14.17 cmand
24108 root      20   0 15688 7248 3648 S    0  0.2   5:37.05 emd
24130 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
24226 root      14  -6  3708 2448 1044 S    0  0.1   0:00.08 pman.sh
24369 root      20   0  979m 348m 343m S    0  9.1  87:39.85 fman_rp
24407 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
24501 root      20   0 14156 6020 3656 S    0  0.2   4568:25 hman
24696 root      20   0 21448 6072 4364 S    0  0.2  45:20.84 imand
24850 root      14  -6  3708 2448 1044 S    0  0.1   0:00.09 pman.sh
24977 root      14  -6  3712 2452 1044 S    0  0.1   0:00.10 pman.sh
25012 root      20   0  4672 1580 1212 S    0  0.0   0:00.00 rotee
25072 root      20   0  4672 1588 1212 S    0  0.0   0:00.01 rotee
25095 root      20   0  4840 3580 1048 S    0  0.1 833:54.79 btrace_rotate.s
25353 root      20   0  4672 1572 1208 S    0  0.0   0:00.00 rotee
25637 root      14  -6  3728 2472 1044 S    0  0.1   0:00.08 pman.sh
25747 root      20   0 78748 2044 1360 S    0  0.1   0:01.15 licensed
25807 root      14  -6  3712 2452 1044 S    0  0.1   0:00.07 pman.sh
25858 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
25868 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
25975 root      14  -6  3712 2456 1044 S    0  0.1   0:00.08 pman.sh
26178 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
26189 root      20   0 11684 5204 2812 S    0  0.1   0:44.81 plogd
26334 root      14  -6  3712 2452 1044 S    0  0.1   0:00.08 pman.sh
26451 root      20   0 14424 4148 2552 S    0  0.1   0:40.50 psd
26488 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
26557 root      14  -6  3728 2468 1044 S    0  0.1   0:00.07 pman.sh
26728 root      20   0  4672 1588 1212 S    0  0.0   0:00.12 rotee
26797 root      20   0 99856  90m 4796 S    0  2.4  14:09.84 smand
27028 root      20   0  4088 2780 1012 S    0  0.1  65:45.58 sort_files_by_i
27052 root      14  -6  3712 2456 1044 S    0  0.1   0:00.07 pman.sh
27123 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
27908 root      20   0  4824 3544 1040 S    0  0.1   4:46.57 periodic.sh
28010 root      20   0  149m 4116 2720 S    0  0.1   0:00.03 vman
28221 root      20   0  4672 1576 1208 S    0  0.0   0:00.00 rotee
28885 root      20   0  1880  516  424 S    0  0.0   0:00.00 sleep
28912 root      20   0     0    0    0 S    0  0.0   0:00.06 pdflush
30174 root      20   0  1880  512  424 S    0  0.0   0:00.00 sleep
30799 root      20   0  3744 2508 1056 S    0  0.1   0:00.27 pvp.sh
30856 root      20   0  4672 1580 1212 S    0  0.0   0:00.00 rotee
31021 root      20   0  1720  500  404 S    0  0.0   0:00.00 inotifywait
31123 root      14  -6  3696 2436 1044 S    0  0.1   0:00.07 pman.sh
31254 root      20   0     0    0    0 S    0  0.0   0:00.00 pdflush
31261 root      14  -6  3692 2432 1040 S    0  0.1   0:00.06 pman.sh
31290 root      20   0  1716  464  376 S    0  0.0   0:00.00 inotifywait
31376 root      14  -6  3688 2428 1044 S    0  0.1   0:00.06 pman.sh
31423 root      20   0  1880  516  424 S    0  0.0   0:00.00 sleep
31496 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
31533 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
31567 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
31636 root      20   0  384m 9.8m 5200 S    0  0.3   3:23.43 cman_fp
31703 root      14  -6  3688 2424 1040 S    0  0.1   0:00.11 pman.sh
31784 root      20   0  1880  512  424 S    0  0.0   0:00.00 sleep
31787 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
32035 root      14  -6  3692 2428 1040 S    0  0.1   0:00.07 pman.sh
32088 root      20   0 1123m  90m  23m S    0  2.3 117:21.15 cpp_cp_svr
32141 root      20   0  4672 1580 1208 S    0  0.0   0:00.00 rotee
32216 root      20   0  1880  516  424 S    0  0.0   0:00.00 sleep
32288 root      14  -6  3692 2432 1040 S    0  0.1   0:00.07 pman.sh
32469 root      20   0  1716  464  376 S    0  0.0   0:00.06 inotifywait
32487 root      20   0  2568 1280 1032 S    0  0.0   0:00.00 bexec.sh
32491 root      20   0  2532 1224 1008 S    0  0.0   0:00.00 mcp_chvrf.sh
32492 root      20   0  2556 1252 1016 S    0  0.0   0:00.00 mcp_monitor_pro
32493 root      20   0  2212 1064  744 R    0  0.0   0:00.00 top
32516 root      20   0  777m  19m 5816 S    0  0.5  54:50.68 cpp_driver
32524 root      20   0  4812 3544 1044 S    0  0.1 275:16.82 btrace_rotate.s
32601 root      20   0  4672 1584 1212 S    0  0.0   0:00.00 rotee
32693 root      20   0  4672 1584 1220 S    0  0.0   0:00.00 rotee
top - 12:24:12 up 232 days, 11:22,  0 users,  load average: 8.51, 8.76, 8.95
Tasks: 227 total,   7 running, 220 sleeping,   0 stopped,   0 zombie
Cpu(s): 36.3%us, 62.0%sy,  0.0%ni,  0.5%id,  0.0%wa,  1.0%hi,  0.2%si,  0.0%st
Mem:   3944724k total,  3865812k used,    78912k free,   107652k buffers
Swap:        0k total,        0k used,        0k free,  1482788k cached
3264 root      20   0 18100 8092 5840 R   87  0.2  13432:08 cmcc
26797 root      20   0 99856  90m 4796 S    8  2.4  14:10.09 smand
24501 root      20   0 14156 6092 3712 S    3  0.2   4568:25 hman
28319 root      20   0 2283m 1.2g 110m R    2 30.9  10559:18 linux_iosd-imag
3263 root      20   0  4832 3560 1044 S    2  0.1 528:03.28 btrace_rotate.s
25095 root      20   0  4840 3580 1048 S    2  0.1 833:54.84 btrace_rotate.s
8402 root      20   0  178m  53m  31m S    1  1.4 411:34.45 mcpcc-lc-ms
1546 root      20   0 1563m 395m  34m R    1 10.3 351:35.55 fman_fp_image
9437 root      20   0  178m  53m  31m S    1  1.4  86:18.73 mcpcc-lc-ms
32493 root      20   0  2220 1144  816 R    1  0.0   0:00.02 top
32587 root      20   0  1612  516  452 R    1  0.0   0:00.02 fuser
23957 root      20   0 48360  11m 8292 S    0  0.3  44:14.18 cmand
32088 root      20   0 1123m  90m  23m S    0  2.3 117:21.16 cpp_cp_svr
    4 root      15  -5     0    0    0 S    0  0.0   4:46.36 ksoftirqd/0
4268 root      20   0 12768 5880 4172 S    0  0.1 123:33.97 imccd
15058 root      15  -5     0    0    0 S    0  0.0   0:40.47 lsmpi-refill
15059 root      15  -5     0    0    0 R    0  0.0  13:40.99 lsmpi-xmit
15060 root      15  -5     0    0    0 S    0  0.0  27:29.69 lsmpi-rx
15732 root      20   0     0    0    0 S    0  0.0   3:40.03 cavium
32588 root      20   0  4832 2740  224 R    0  0.1   0:00.00 btrace_rotate.s
top - 12:24:15 up 232 days, 11:22,  0 users,  load average: 8.51, 8.76, 8.95
Tasks: 227 total,   9 running, 218 sleeping,   0 stopped,   0 zombie
Cpu(s): 37.3%us, 60.9%sy,  0.0%ni,  0.8%id,  0.0%wa,  1.0%hi,  0.0%si,  0.0%st
Mem:   3944724k total,  3868680k used,    76044k free,   107652k buffers
Swap:        0k total,        0k used,        0k free,  1485800k cached
3264 root      20   0 18100 8092 5840 R   88  0.2  13432:11 cmcc
26797 root      20   0 99856  90m 4796 S    8  2.4  14:10.33 smand
32688 root      20   0  1716  464  376 S    2  0.0   0:00.07 inotifywait
3263 root      20   0  4832 3560 1044 R    2  0.1 528:03.33 btrace_rotate.s
25095 root      20   0  4840 3580 1048 S    1  0.1 833:54.88 btrace_rotate.s
9437 root      20   0  178m  53m  31m R    1  1.4  86:18.76 mcpcc-lc-ms
1104 root      15  -5     0    0    0 D    0  0.0  13:36.03 usb-storage
1546 root      20   0 1563m 395m  34m R    0 10.3 351:35.56 fman_fp_image
8402 root      20   0  178m  53m  31m R    0  1.4 411:34.46 mcpcc-lc-ms
15060 root      15  -5     0    0    0 S    0  0.0  27:29.70 lsmpi-rx
24369 root      20   0  979m 348m 343m S    0  9.1  87:39.86 fman_rp
32493 root      20   0  2220 1144  816 R    0  0.0   0:00.03 top
    9 root      15  -5     0    0    0 R    0  0.0   0:36.86 events/0
24501 root      20   0 14156 6092 3712 S    0  0.2   4568:25 hman
32700 root      20   0  4832 2596   80 S    0  0.1   0:00.00 btrace_rotate.s
top - 12:24:18 up 232 days, 11:22,  0 users,  load average: 8.87, 8.83, 8.97
Cpu(s): 36.9%us, 62.0%sy,  0.0%ni,  0.2%id,  0.0%wa,  1.0%hi,  0.0%si,  0.0%st
Mem:   3944724k total,  3872160k used,    72564k free,   107652k buffers
Swap:        0k total,        0k used,        0k free,  1488956k cached
3264 root      20   0 18100 8092 5840 R   80  0.2  13432:13 cmcc
26797 root      20   0 99856  90m 4796 S    8  2.4  14:10.57 smand
24501 root      20   0 14156 6092 3712 S    2  0.2   4568:25 hman
3263 root      20   0  4832 3560 1044 S    2  0.1 528:03.39 btrace_rotate.s
25095 root      20   0  4840 3580 1048 S    2  0.1 833:54.93 btrace_rotate.s
  315 root      20   0  1608  512  452 R    1  0.0   0:00.03 fuser
8402 root      20   0  178m  53m  31m S    1  1.4 411:34.48 mcpcc-lc-ms
9437 root      20   0  178m  53m  31m S    0  1.4  86:18.77 mcpcc-lc-ms
24369 root      20   0  979m 348m 343m S    0  9.1  87:39.87 fman_rp
    7 root      15  -5     0    0    0 R    0  0.0   5:18.25 ksoftirqd/1
  316 root      20   0  4832 2740  224 R    0  0.1   0:00.00 btrace_rotate.s
1104 root      15  -5     0    0    0 R    0  0.0  13:36.03 usb-storage
15060 root      15  -5     0    0    0 R    0  0.0  27:29.70 lsmpi-rx
top - 12:24:21 up 232 days, 11:22,  0 users,  load average: 9.20, 8.90, 8.99
Tasks: 227 total,   8 running, 219 sleeping,   0 stopped,   0 zombie
Cpu(s): 36.9%us, 61.9%sy,  0.0%ni,  0.3%id,  0.0%wa,  0.8%hi,  0.0%si,  0.0%st
Mem:   3944724k total,  3875428k used,    69296k free,   107652k buffers
Swap:        0k total,        0k used,        0k free,  1492176k cached
3264 root      20   0 18100 8092 5840 R   80  0.2  13432:16 cmcc
26797 root      20   0 99856  90m 4796 S    8  2.4  14:10.81 smand
  418 root      20   0  1716  464  376 S    2  0.0   0:00.07 inotifywait
3263 root      20   0  4832 3560 1044 S    2  0.1 528:03.46 btrace_rotate.s
25095 root      20   0  4840 3580 1048 S    2  0.1 833:54.98 btrace_rotate.s
8402 root      20   0  178m  53m  31m R    1  1.4 411:34.51 mcpcc-lc-ms
1546 root      20   0 1563m 395m  34m S    1 10.3 351:35.58 fman_fp_image
9437 root      20   0  178m  53m  31m R    1  1.4  86:18.79 mcpcc-lc-ms
32493 root      20   0  2220 1144  816 R    1  0.0   0:00.05 top
24696 root      20   0 21448 6072 4364 S    0  0.2  45:20.85 imand
  425 root      20   0  4832 2596   80 R    0  0.1   0:00.00 btrace_rotate.s
32516 root      20   0  777m  19m 5816 R    0  0.5  54:50.68 cpp_driver
r1-2-asr-king-mel#
r1-2-asr-king-mel#show platform software status control-processor brief
Load Average
Slot  Status  1-Min  5-Min 15-Min
  RP0 Warning  10.09   9.21   9.09
Memory (kB)
Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  3944724  3859740 (98%)    84984 ( 2%)   3663948 (93%)
CPU Utilization
Slot  CPU   User System   Nice   Idle    IRQ   SIRQ IOwait
  RP0    0  35.62  62.37   0.00   0.99   0.89   0.09   0.00
         1  33.16  65.83   0.00   0.00   0.99   0.00   0.00
Jing
Hi Jing,
I see the CPU is very high for cmcc:
This is likely to be a result of the following bug:
     CSCua27350    ASR1001 OIR of SPA module causes high cpu at cmcc
Workaround: reload must be issued to clear the high cpu.
It is fixed in 15.2(04)S, 15.2(02)S02, 15.1(03)S04 and later releases.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
Do you know what actually triggered this bug?
I would like to know whether this could happen again on the same IOS.
Thank you
Jing
Hi Jing,
It is usually some event related to SPA, e.g. reset.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
That explains it, as we recently instaledl the 5GE card (SPA-5X1GE-V2), it seems that this problem started afterwards.
So, apart from the reload, do we need to uninstall the card? Would the card be working fine after the reload
Thank you
Jing
Hi Jing,
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
Thanks a lot for your assistance.
Jing
Hello guys,
Thanks for your active participation on community .keep on sharing your knowledge to help others
The Above discussion has converted into document on community, please find the below link for your reference
"The Users receive the PLATFORM-4-ELEMENT_WARNING: warning messages on ASR 1001 platform"
Ashish Shirkar
(Community Manager-Network Infrastructure)
