871W as PPTP Client issue (Double NAT / Bridging Issue)
antwharmby
I have trying to solve this for a while now without success so I think its time to enlist some help.
I have a Cisco 871W connected to a cable modem for WAN which works without an issue. What I am trying to do is create an PPTP tunnel and route certain traffic down it. For now just to test and get everything working lets suppose I just need one machine to use the PPTP tunnel for all internet connections.
The PPTP dialer connects to another ISP in the UK (I'm in the US), the connection works however it is extremely slow due to what I would assume to be double NAT. Currently the dialer interface is obtaining an IP from the ISP (DHCP 192.168.100.6) and hosts on my side NAT overload via this connection to the internet in the UK. (Dialer 1)
What I want to do is "bridge" this dialer interface so that it no longer has an IP, and the IP from the ISP is given to a host on my side to remove a layer of NAT. Is this possible?
Here are some sections of the config as it stands:
vpdn enable
vpdn-group 1
request-dialin
  protocol pptp
  rotary-group 1
initiate-to ip EXTERNALIPOFISP
bridge irb
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
ip address dhcp
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan10
no ip address
bridge-group 1
interface Dialer1
mtu 1440
ip tcp adjust-mss 1400
ip address negotiated
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 1
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp encrypt mppe auto
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
interface BVI1
ip address INTERNALIP 255.255.255.0
ip nat inside
ip policy route-map TEST
ip nat inside source route-map TEST interface Dialer1 overload
access-list 101 permit ip host INTERNALHOST any
route-map TEST permit 101
match ip address 101
set interface Dialer1
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Thanks in advance for any assistance.
0 Replies 0
