EBGP issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-01-2012 04:34 AM - edited 03-04-2019 04:32 PM
Hi experts,
I am facing a issue with BGP connectivity with two remote location. I am creating EBGP neighbor ship with loopback and using two different media. After configuration the BGP was up and I am facing issue during failover scenario. Please find the details.
- Individual L3 links between A location-B location routers.
- Loopback interfaces on both end routers used.
- Two static routes need to be added for B-loopback loopback on A-location router pointing to both WAN IPs.
- Similarly on B-location router two static routes for A-location loopback.
- BFD needs to be configured for static routing on individual links(300ms x 3times).
- BGP peering will be done with loopbacks on each ends.
Whenever one media fails the BGP is getting down after some time. Kindly suggest.
Configuration scripts attached for reference along with failover logs.
Naveen
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2012 05:22 AM
Naveen,
Configure BFD support for BGP as well, if you need to decrease the fail-over time...
Refer following link:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fs_bfd.html
HTH,
Smitesh
Please rate if helpful.
Message was edited by: smitesh kharecha
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2012 10:32 AM
Hi Smitesh,
I have used bfd on interfaces and configured " neighbor X.X.X.X fall-over bfd " in bgp. Please let me know anyother options are there?
Br,
Naveen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2012 06:40 AM
Hello Naveen,
I would try to use different names or groups for the two static routes used to reach the loopback on the other site
You currently have the following configuration:
ip route static bfd GigabitEthernet2/34 10.196.108.9
ip route static bfd GigabitEthernet3/9 10.196.108.13
ip route 10.196.108.24 255.255.255.255 10.196.108.9 name BGP_B_loc
ip route 10.196.108.24 255.255.255.255 10.196.108.13 name BGP_B_loc
ip route 10.196.108.9 255.255.255.255 GigabitEthernet2/34 10.196.108.9 name BGP_B_loc
ip route 10.196.108.13 255.255.255.255 GigabitEthernet3/9 10.196.108.13 name BGP_B_Loc
I would use different names as actually the next-hops are different and the name option refers to a next-hop name
ip route 10.196.108.24 255.255.255.255 10.196.108.9 name BGP_B_loc1
ip route 10.196.108.24 255.255.255.255 10.196.108.13 name BGP_B_loc2
ip route 10.196.108.9 255.255.255.255 GigabitEthernet2/34 10.196.108.9 name BGP_B_loc1
ip route 10.196.108.13 255.255.255.255 GigabitEthernet3/9 10.196.108.13 name BGP_B_Loc2
and I would do the same on the other location
see BFD configuration guide
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2012 10:29 AM
Hi Giuseppe,
Both links are going to same router (A-B connectivity). And name is only used for identification of static routes, I think.
Naveen
