877 ADSL connection issue
Problem summary: ADSL router fails to bring up BT ADSL connection
We have set up a 877 ADSL router (UK ADSL POTS) and receive the following debug information following a 'debug atm events'
Mar 1 00:24:03.027: DSL: Send ADSL_OPEN command.
*Mar 1 00:24:03.027: DSL(ATM0): Using subfunction 0x0
*Mar 1 00:24:03.027: LOCAL:Max noise margin for power cutoff 31
*Mar 1 00:24:03.027: DSL(ATM0): Sent command 0x3
*Mar 1 00:24:05.527: DSL(ATM0): 1: Modem state = 0x9
*Mar 1 00:24:08.027: DSL(ATM0): 2: Modem state = 0x10
*Mar 1 00:24:10.527: DSL(ATM0): 3: Modem state = 0x10
*Mar 1 00:24:13.027: DSL(ATM0): 4: Modem state = 0x10
*Mar 1 00:24:14.115: DSL: Received response: 0x22
*Mar 1 00:24:14.115: DSL: Open failed: Error in early non-CRC message or in fir
st CRC-covered message -- retrying
*Mar 1 00:24:14.115: sleep 5 seconds
*Mar 1 00:24:19.115: DSL: Send ADSL_OPEN command.
*Mar 1 00:24:19.115: DSL(ATM0): Using subfunction 0x0
*Mar 1 00:24:19.115: LOCAL:Max noise margin for power cutoff 31
*Mar 1 00:24:19.115: DSL(ATM0): Sent command 0x3
*Mar 1 00:24:21.615: DSL(ATM0): 1: Modem state = 0x9
*Mar 1 00:24:24.115: DSL(ATM0): 2: Modem state = 0x10
ATM interface Configuration
interface ATM0
description ** Connection to ISP via ADSL **
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
We have tried the BT router/modem and all works fine
We have extensively searched the web for the 'open failed' error
Any help on this would be much appreciated.
can you try and set the ´dsl operating-mode´to ansi-dmt ?
dsl operating-mode ansi-dmt
and see if that makes a difference ?
GP
Hi All!
I'm also having some grief with an 877 (in the UK)... the most progress I've made so far is to go to this URL:
ftp://ftp.cisco.com/pub/access/800
Download the 3.0.10 ADSL firmware. Copy it to flash, and rename to this name exactly:
adsl_alc_20190.bin
This got mine trained up! Prior to this it appeared to be dead...
Now if it would just pass a few packets I'd be laughing.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
If you do "show atm pvc" do you see data passing ?
Are you positive about encapsulation used and relative configuration ?
