877 - DSL config
dcooke
Hi Guys
Couldn't find any answer to this anywhere so hope someone can help.
We are trying to connect our 877 DSL router to Verizon DSL. Of course they are no help at all as once you tell them you are using a Cisco router you may as well admit to having the Ebola virus!
I know the PVC settings are 0/35 from the previous router. I'm not sure about the encapulsation type. The last router had it as "routed bridge". I therefore presume that it should be RFC 1483 (aal5snap)?
Nothing is going on though. Here is the ATM config:
Interface ATM0
no ip address
no ip-route cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address xxxxx
ip nat outside
ip virtual-reassembly
no ip route-cache
pvc 0/35
encapsulation aal5snap
I have tried a few encapsulation types but with no luck. I can't ping the DSL gateway, also I can't ping the local ATM0.1 interface! is this normal.
Anyway - any help appreciated.
Dan
15 Replies 15
1. Indeed.
2. SDM often do wrong things. Avoid using it.
3. There is no relationship. Routing needs to be enabled.
Thanks for the appreciation and good luck!
