877 router has crc errors but the input errors counter is not incrementing
catotten
Hi, I have an 877 router that is configured with an atm pvc facing the wan. The atm0 interface crc errors are incrementing, but these errors are not being reflected in the input errors counter. Does anybody know why this is?
JDI-KBSDAR-CE1#sh int atm0
ATM0 is up, line protocol is up
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 640 Kbit, DLY 570 usec,
reliability 255/255, txload 6/255, rxload 8/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 1024 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 22:42:08
Input queue: 0/224/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Per VC Queueing
30 second input rate 21000 bits/sec, 7 packets/sec
30 second output rate 16000 bits/sec, 10 packets/sec
957301 packets input, 609662204 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 2040 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
978302 packets output, 164802240 bytes, 0 underruns
When the CRC error counter is incremented the following ATM error is logged when debug atm errors is enabled:
ATM0: AAL5 rx errors (status = 0C110000)
The router ios is: c870-advipservicesk9-mz.124-9.T2.bin
6 Replies 6
JORGE RODRIGUEZ
Level 10
Level 10
Would this cause packet loss? Because i am getting packet loss:
ABC123#ping 10.1.254.101 size 500 repeat 5000
Sending 5000, 500-byte ICMP Echos to 10.1.254.101, timeout is 2 seconds:
*May 29 07:00:19 UTC: ATM0: AAL5 rx errors (status = 0C130000).!!!!!!!!!!!!!!!!!!!!
*May 29 07:00:23 UTC: ATM0: AAL5 rx errors (status = 0C130000)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
*May 29 07:00:37 UTC: ATM0: AAL5 rx errors (status = 0C110000)
*May 29 07:00:37 UTC: ATM0: AAL5 rx errors (status = 0C110000).!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
*May 29 07:00:41 UTC: ATM0: AAL5 rx errors (status = 0C110000).!!!!!!!!!!
*May 29 07:00:42 UTC: ATM0: AAL5 rx errors (status = 0C110000)
*May 29 07:00:42 UTC: ATM0: AAL5 rx errors (status = 2C130000)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Success rate is 99 percent (4997/5000), round-trip min/avg/max = 16/19/192 ms
Have you checked physical issues on pvc carrier from the wan side.
Check out this case from tac knowledge base
http://www.ciscotaccc.com/kaidara-advisor/atm/showcase?case=K16470263
Jorge Rodriguez
I am pretty sure that there is an issue with the carrier side, however, my question is. Why aren't the CRC errors showing up as an input error on the routers atm interface? Aren't the input errors supposed to be a running count of CRCs, "no buffers", runts, giants, frames, overruns, ignored, aborts and other input-related errors?
Im goint to look this up, I could be wrong on this one and please someone can correct on this , the input/output statistics would more have to do with the way incoming and outgoing packets are processed withing the router itself, I would assume crc would indicate physical issues, and that is why your input errors are 0 and is not directly related to input/output errors in this case.
Jorge Rodriguez
I do see that on really all my installed ADSL router (and they're quite a number), independently from IOS used, but only when PPPoA is used, and only with certain DSLAM/BRAS.
I cannot tell that is causing any particular problem as I cannot demonstrate packet loss because of this.
You have to know that "show interface" is a bit particular for the way it accounts and sums or not sums errors, for reasons that is impossible to summarize here.
