877w PPPoA issue
liamconnelly
Still studying my CCNA, so im using this router as a bit of a learning incentive. So far it looks like ive got all of the DHCP and wireless stuff working ok, but i cant seem to get it to hit my ISP which is TalkTalk (UK). Heres my current config,
urrent configuration : 2267 bytes
version 12.4
no service pad
hostname R877W
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
dot11 ssid lab
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 ______________
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.14 192.168.1.15
ip dhcp excluded-address 192.168.1.30 192.168.1.16
ip dhcp pool LAN
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   domain-name HomeLan
   dns-server 62.24.139.8 62.24.202.70
ip dhcp pool Wlan
   network 192.168.60.0 255.255.255.0
   default-router 192.168.60.1
ip name-server 62.24.139.8
ip name-server 62.24.202.70
username admin privilege 15 password 0 ______________
archive
log config
  hidekeys
bridge irb
interface ATM0
description ADSL Connection
no ip address
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl enable-training-log
dsl bitswap both
hold-queue 200 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
ip address 192.168.60.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no shutdown
encryption mode ciphers tkip
ssid Cisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2447
station-role root
interface Vlan1
ip nat inside
interface Dialer0
bandwidth inherit
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp header-compression iphc-format
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname _______________________
ppp chap password _______________________
ppp ipcp dns request
ppp ipcp wins request
ip rtp header-compression iphc-format
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 10 interface Dialer0 overload
access-list 10 permit any
control-plane
line con 0
logging synchronous
login local
no modem enable
line aux 0
password aux
login
line vty 0 4
login
scheduler max-task-time 5000
end
I dont get any of the ADSL lights flashing at all, ive pieced this together from other configs posted on the web so there may be some glaring errors. Any help would be appreciated. Here is some of the current info from my isp
[img]http://imgur.com/WzX3LGq[/img]
Liam
hello
What authentication are.you using -PAP.or CHAP?
i think you only need chap username and password no need to.set callin.if anything it should be callout
if PAP i would try ppp pap sent-username xxx password xxx
also for your natting i would suggest to change your acl
no access-list 10
access-list 10 permit 192.168.1.0 0.0.0.255
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
hello
no access-list 10
res
paul
Kind Regards
Paul
Thanks Paul
That was a massive help! managed to get to get the dialer up and fix the NAT with your advice cheers. Ive tidied some bits up and got the wifi working so if any other TalkTalk PPPoA users need a config this should help you.
Current configuration : 3256 bytes
version 12.4
no service pad
service password-encryption
hostname **************
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password 7 *************
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone GMT 0
clock summer-time BST recurring
dot11 syslog
dot11 ssid *********
vlan 1
authentication open
guest-mode
wpa-psk ascii 7 *******************
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.32
ip dhcp pool LAN
   dns-server 4.2.2.2 4.2.2.3 8.8.8.8
ip cef
ip domain name **********
ip name-server 4.2.2.2
ip name-server 8.8.8.8
ip inspect name wan_inspect_out ftp timeout 30
ip inspect name wan_inspect_out tcp timeout 30
ip inspect name wan_inspect_out udp router-traffic timeout 15
ip inspect name wan_inspect_out icmp router-traffic timeout 15
no ipv6 cef
username admin privilege 15 secret 5 ********************
archive
log config
  hidekeys
ip ssh version 2
bridge irb
interface ATM0
no ip address
no ip mroute-cache
pvc 0/38
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid **************
channel 2442
station-role root
world-mode dot11d country GB indoor
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface Dialer1
ip access-group wan_acl_in in
ip nat outside
ip inspect wan_inspect_out out
encapsulation ppp
dialer pool 1
ppp chap hostname ******************@talktalk.net
ppp chap password  ****************************
ppp pap sent-username **************@talktalk.net password ********************
interface BVI1
ip nat inside
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip dns server
ip nat inside source list INSIDE-NAT interface Dialer1 overload
ip access-list extended INSIDE-NAT
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended wan_acl_in
permit ip host ************** any
deny   ip any any log
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
transport input ssh
end
___________________________________________
Ignore the extended WAN_ACL thats so i can connect from my workplace. But the rest is good , any ********* sections needs  your input. There is also some DHCP exclude addresses you may want to delete, the wifi is bridged to VLAN1
Cheers
Liam
Hello Liam,
Thanks for the rating much appreciated - and also for your feedback.
This is what CSC is all about, Assisting others and hopefully being able to look at older posts for a correct solution.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
