High CPU edge router
zyang
My edge router is pegged at 80% and interrupts at 8%.  None of the processes show up as being high.  What is the next step to troubleshoot this?  How do I find out what is using all this CPU?  below is the show proc cpu sort command.  and show proc cpu history.
CEF is enabled.
CPU utilization for five seconds: 78%/7%; one minute: 78%; five minutes: 77%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  65  3659260336 390589358       9368  5.14%  5.82%  5.82%   0 IP Input
103     2935808 123190216         23  0.16%  0.14%  0.14%   0 TCP Timer
118      929632 220585332          4  0.08%  0.01%  0.00%   0 Inspect process
  71    21172428 121535238        174  0.08%  0.03%  0.02%   0 BGP I/O
226        4480      2834       1580  0.08%  0.09%  0.06% 196 SSH Process
  18     9694672  79550472        121  0.08%  0.00%  0.00%   0 EEM ED Syslog
104      350964    429432        817  0.08%  0.07%  0.08%   0 TCP Protocols
   8           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
   9        6484   3767064          1  0.00%  0.00%  0.00%   0 Environmental mo
  10           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  11     2399092   9123552        262  0.00%  0.00%  0.00%   0 ARP Input
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
  13           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  14           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  15           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  16           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
   6       96624    119331        809  0.00%  0.00%  0.00%   0 Pool Manager
  12           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  19       73864   5650559         13  0.00%  0.00%  0.00%   0 HC Counter Timer
   5    96382516  13484167       7147  0.00%  0.06%  0.05%   0 Check heaps
  21           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  22           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  23           0         2          0  0.00%  0.00%  0.00%   0 SMART
  24      272820 113013132          2  0.00%  0.00%  0.00%   0 GraphIt
  25           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  26           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  27           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  28          44      7793          5  0.00%  0.00%  0.00%   0 IP RACL Ager
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
  17           8         2       4000  0.00%  0.00%  0.00%   0 Entity MIB API
  20           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  32           4         2       2000  0.00%  0.00%  0.00%   0 IDB Work
  33     1502748 148454142         10  0.00%  0.01%  0.00%   0 Logger
  34      400944 112974797          3  0.00%  0.00%  0.00%   0 TTY Background
  35     2679652 113013290         23  0.00%  0.04%  0.05%   0 Per-Second Jobs
  36           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  29           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  38         104        25       4160  0.00%  0.00%  0.00%   0 ESWPPM
  39           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  40        7460   1263048          5  0.00%  0.00%  0.00%   0 Time Range Proce
  41           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  42           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  43           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  44           0         2          0  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
  45          32       213        150  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  46          32       219        146  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  47           0         1          0  0.00%  0.00%  0.00%   0 Platform Compact
  48        6268   3767065          1  0.00%  0.00%  0.00%   0 Call Management
  49          12        23        521  0.00%  0.00%  0.00%   0 Switch Link Moni
  50      191172 112974880          1  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  51           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
   3     2202200 175147099         12  0.00%  0.03%  0.02%   0 Spanning Tree
  53           0         1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  30           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  55           0         2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  56     9471696 423966835         22  0.00%  0.01%  0.00%   0 BGP Router
  31      350220  50938407          6  0.00%  0.00%  0.00%   0 Net Background
  58           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  37           0         1          0  0.00%  0.00%  0.00%   0 Token Daemon
  60           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  61       29376    417852         70  0.00%  0.00%  0.00%   0 AAA Server
  62           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  63           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  64     1376428  18054357         76  0.00%  0.00%  0.00%   0 CDP Protocol
   2     2662872  22602652        117  0.00%  0.04%  0.05%   0 Load Meter
  66       36236   5410033          6  0.00%  0.00%  0.00%   0 ICMP event handl
  67           4      1072          3  0.00%  0.00%  0.00%   0 TurboACL
  68           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  69       39752    449634         88  0.00%  0.00%  0.00%   0 MOP Protocols
  70           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  54      220916 112974945          1  0.00%  0.00%  0.00%   0 linktest
  72           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  73       26788  15068075          1  0.00%  0.00%  0.00%   0 SSS Test Client
  74           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  75     1297980 441409045          2  0.00%  0.01%  0.00%   0 SSS Feature Time
  76           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  77           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  78           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  79           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  80           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  81           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  82           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
  83           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
  84      167740   3252239         51  0.00%  0.00%  0.00%   0 IP Background
  85       38212   1914227         19  0.00%  0.00%  0.00%   0 IP RIB Update
  86           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  87           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  88     1225764 180111159          6  0.00%  0.01%  0.00%   0 CEF process
  89      284216 112931728          2  0.00%  0.00%  0.00%   0 Socket Timers
  90           8      1766          4  0.00%  0.00%  0.00%   0 L2MM
  91          40       220        181  0.00%  0.00%  0.00%   0 MRD
  92           0        43          0  0.00%  0.00%  0.00%   0 IGMPSN
  93     2624420 225863448         11  0.00%  0.03%  0.02%   0 DHCPD Receive
  94           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
  95           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
  96           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  97           4         2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
  98           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
  99      385808 112974915          3  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
100           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
101      180908 112974905          1  0.00%  0.00%  0.00%   0 bsm_xmt_proc
102           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
  52           0        15          0  0.00%  0.00%  0.00%   0 dot1x
   1         664       848        783  0.00%  0.00%  0.00%   0 Chunk Manager
105           0         1          0  0.00%  0.00%  0.00%   0 COPS
106           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
107       28160   1883493         14  0.00%  0.00%  0.00%   0 IP Cache Ager
108       95744   1883547         50  0.00%  0.00%  0.00%   0 Adj Manager
109           4         2       2000  0.00%  0.00%  0.00%   0 ATM OAM Input
110           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
111      145828    473546        307  0.00%  0.00%  0.00%   0 HTTP CORE
112           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  57           0         2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
  59           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
115           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
116           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
117     33750761127424862          2  0.00%  0.03%  0.02%   0 RBSCP Background
113           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
119        4036    941775          4  0.00%  0.00%  0.00%   0 DHCPD Timer
120         976    376711          2  0.00%  0.00%  0.00%   0 Authentication P
121           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
122           0         1          0  0.00%  0.00%  0.00%   0 IPS Timer
123           0         2          0  0.00%  0.00%  0.00%   0 SDEE Management
124           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
125           0         2          0  0.00%  0.00%  0.00%   0 URL filter proc
126           8         3       2666  0.00%  0.00%  0.00%   0 Crypto HW Proc
127       16764   4520532          3  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
128      163600  41820278          3  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
129       58628  41820276          1  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
130    30796160   7434014       4142  0.00%  0.01%  0.00%   0 BGP Scanner
131           0         2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
132           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
133           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
134           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
135           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
136       51864    417852        124  0.00%  0.01%  0.00%   0 LOCAL AAA
137           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
138           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
139           0         3          0  0.00%  0.00%  0.00%   0 Crypto WUI
140           0         2          0  0.00%  0.00%  0.00%   0 Crypto Support
141           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
142           0         2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
143           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
144         268    125571          2  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
145           0         2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
146           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
147           0       264          0  0.00%  0.00%  0.00%   0 HSRP Common
148           0         1          0  0.00%  0.00%  0.00%   0 http client proc
149          88        77       1142  0.00%  0.00%  0.00%   0 CCH323_CT
150           0         1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
151           4         2       2000  0.00%  0.00%  0.00%   0 CCAAL2_CT
152           0         2          0  0.00%  0.00%  0.00%   0 CCFRF11_CT
153     1832264    509987       3592  0.00%  0.00%  0.00%   0 CCSIP_SPI_CONTRO
154           0         1          0  0.00%  0.00%  0.00%   0 CCSIP_DNS
155      596392    797031        748  0.00%  0.00%  0.00%   0 CCSIP_UDP_SOCKET
156          32       197        162  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
157      143952   1965788         73  0.00%  0.00%  0.00%   0 traffic_shape
158           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
159           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
160           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
161           4        12        333  0.00%  0.00%  0.00%   0 crypto engine pr
162          32         4       8000  0.00%  0.00%  0.00%   0 Crypto CA
163           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
164           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
165           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
166        2336     18312        127  0.00%  0.00%  0.00%   0 Crypto ACL
167           0         2          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
168           0         1          0  0.00%  0.00%  0.00%   0 Crypto INT
169           0         4          0  0.00%  0.00%  0.00%   0 Crypto IKMP
170       17404   5650563          3  0.00%  0.00%  0.00%   0 IPSEC key engine
171           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
172           0         1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
173           0         2          0  0.00%  0.00%  0.00%   0 Key Proc
174           0         1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
175      232944 113013138          2  0.00%  0.00%  0.00%   0 Crypto Device Up
176           0         2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
177           0         1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
178      183644  32010030          5  0.00%  0.00%  0.00%   0 PM Callback
179     1412192 564928991          2  0.00%  0.01%  0.00%   0 Atheros LED Ctro
180           0         2          0  0.00%  0.00%  0.00%   0 Control-plane ho
181           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
182           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
183           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
184     2848500  38010126         74  0.00%  0.01%  0.00%   0 HSRP IPv4
185           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
186           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Counter
187           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Interface
188           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
189           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Memory-th
190           0         2          0  0.00%  0.00%  0.00%   0 EEM ED None
191           0         2          0  0.00%  0.00%  0.00%   0 EEM ED OIR
192           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Resource
193           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
194        9476   1883644          5  0.00%  0.00%  0.00%   0 EEM ED Timer
195           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Track
196       90136  24341533          3  0.00%  0.00%  0.00%   0 EEM Server
197       20436  11300918          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
198           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
199           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
200          20         2      10000  0.00%  0.00%  0.00%   0 VLAN Manager
201        2956   1883549          1  0.00%  0.00%  0.00%   0 DHCPD Database
202      244488 112846050          2  0.00%  0.00%  0.00%   0 trunk conditioni
203           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
204           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
205     5445956  74591605         73  0.00%  0.04%  0.05%   0 Syslog
206           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
207      239888   6311492         38  0.00%  0.00%  0.00%   0 IP SLAs Event Pr
208           0        21          0  0.00%  0.00%  0.00%   0 Net Input
209      569360  22602683         25  0.00%  0.00%  0.00%   0 Compute load avg
210    32977268   1909947      17266  0.00%  0.03%  0.00%   0 Per-minute Jobs
211       96992   3919547         24  0.00%  0.00%  0.00%   0 CEF Scanner
212     1887592      9886     190935  0.00%  0.00%  0.00%   0 crypto sw pk pro
213           0         1          0  0.00%  0.00%  0.00%   0 tHUB
214           0         2          0  0.00%  0.00%  0.00%   0 tENM
215         460      2876        159  0.00%  0.00%  0.00%   0 SSH Event handle
216         228       433        526  0.00%  0.00%  0.00%   0 TCP Listener
217    53965516 117099189        460  0.00%  0.05%  0.05%   0 IP SNMP
218    14740996  57836129        254  0.00%  0.01%  0.00%   0 PDU DISPATCHER
219    91337708  57836954       1579  0.00%  0.10%  0.08%   0 SNMP ENGINE
220           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
221           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
222      546544 113189644          4  0.00%  0.00%  0.00%   0 NTP
223        1012        15      67466  0.00%  0.00%  0.00% 194 SSH Process
224        1000         8     125000  0.00%  0.00%  0.00% 195 SSH Process
225      115968  10818533         10  0.00%  0.00%  0.00%   0 Track
114           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
    8877777888887777788888777777777777777777777777788888888888
    6677777000006666622222555556666688888999995555533333444442
100
90 **
80 ************************************************************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    8888888887888988998899889989889889888988899888988899999898
    4847203239886078007726971074980981769266821888098815122919
100                      *                             *
90  * *      **************************************************
80 ####******############################*###*#################
70 ############################################################
60 ############################################################
50 ############################################################
40 ############################################################
30 ############################################################
20 ############################################################
10 ############################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    9998998999899889888876875998695562463239453245566645555633323429353622
    5608971144811769712891133388496979120709760766093791332097290899182589
100 **  **         *          *  *         *                       *
90 ****** **********  *     *** *         *                       *
80 ##******************* *  *** *         *                       *
70 ###*##*#########***** ** *#* *  *      *       * *             *   *
60 #################*#***** *#******  *   * *   * ***     *       * * *
50 ####################******##*****  *   ***  ************     * * * *
40 #####################**#**####*** **   ***  *****#********   * * * *  **
30 ########################**#####**************###########****************
20 ########################*#######***#***#*****###########****************
10 ########################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
zyang
Also the interface for outbound traffic is:
  5 minute input rate 627000 bits/sec, 182 packets/sec
  5 minute output rate 493000 bits/sec, 201 packets/sec
Which doesn't suggest alot of traffic flowing through.
There is a huge ACL and FW inspection is on.  Though with that little traffic, I don't see why it could cause such high cpu loads.
Thanks and any help would be appreciated in diagnosing the problem.
enable netflow on Router.
All thing will be clear to you, which port and ip using cpu.
***Do Rate Helpful Posts***
Jawad
Jawad
